Question about Nextbook NEXT2 Touch Screen Android Tablet
What is the star icon on my status bar - Nextbook NEXT2 Touch Screen Android Tablet
Posted by Fred hart on
Justin
  • Nextbook Master
  • 2,072 Answers
Expand the notification area and click on the icon to see what it is. If you are referring to a star icon in a browser then that typically indicates bookmarks
Posted on Jan 14, 2016
My Acer iconia one 7 model B1-770 has a star in the status bar next to the WiFi thing and I would like to know what it means
The asterisk is there to show that other wireless networks are available for connection. If you tap the asterisk you should reveal the other networks names and signal strength.
Jan 22, 2018 | Acer Tablets & eReaders
Won't reload on my ipad
Connect to wall outlet Uses the USB power adapter and USB cable included with the device. If it is a third-party accessory, check to see if it is Apple Certified . Then follow these steps:
  1. Connect the iPhone, iPad or iPod touch to the Lightning to USB connector cable or the 30-pin to USB connector cable .
  2. Connect it to one of three power sources:
Wall outlet
Connect the charging cable to a USB AC adapter and connect the USB AC adapter to the wall outlet.
Computer
Connect the charging cable to a USB 2.0 or 3.0 port on a computer that is not in sleep mode. Do not use the USB ports on the keyboard.
Power supply
Connect the cable to a powered USB hub, docking station, or other Apple-certified accessory.
When the device is charging, you will see a lightning bolt next to the battery icon in the status bar or a large battery icon on the lock screen.
Aug 12, 2017 | Tablets & eReaders
What is the star icon in my status bar. Where can I find an icon glosary
Star Icon is likely the favorites option in google chrome browser. The nextbook comes with a preinstalled help guide that details the icons
Jan 14, 2016 | Nextbook NEXT2 Touch Screen Android Tablet
Screen does not show a status bar any longer. how to I recover it?
Amazon.com Kindle Help Forum
www.amazon.com/gp/help/.../kindleqna?ie...
Amazon.com, Inc.If you have a newer Fire you swipe down from the top of the home screen to open it. ...I can't get the settings bar to show up, because swiping doesn't work. .... Does anyone out there have any ideas on this problem? .... have erased ALL of them) still no status bars/times/access to anything. oh and mine is the kindle fire hd.
About Charging Your Kindle Fire - Amazon.com
www.amazon.com/gp/help/.../display.html?ie=UTF8...
Amazon.com, Inc.Kindle Fire 2nd Generation: Fully charges in 3.3 hours; Kindle Fire HD 7": Fully ... The battery indicator at the top of your screen should also have a lightning ... You can showthe percentage of the battery charge in the Status Bar at the ... Your Kindle Fire will not charge as efficiently when connected to a computer and in use.
Navigating Your Kindle Fire HD 8.9 - Amazon.com
Dec 25, 2015 | Amazon Kindle Fire HD
How do i turn off the text to speech feature? It has been accidentally turn ed on 3 times. can't get to settings to turn off.
Step 1
Swipe the Status bar at the top of the screen towards the bottom of the screen to display the Quick Settings menu, and then tap "More." To open the Quick Settings menu in Explore by Touch mode, use two fingers to swipe down the Status bar.
Step 2
Tap "Accessibility" to view all settings related to accessibility. Locate the Text-to-Speech and Voice Guide options in the menu.
Step 3
Turn off the "Text-to-Speech" and "Voice Guide" options to disable the voice capabilities of your Kindle Fire HD.
Jul 29, 2015 | Amazon Kindle Fire HD 8.9"
Forgot password to my kindle fire. How do I reset
1 Connect the Kindle Fire to your computer using a USB cable.
2 Wait for your computer to recognize the Kindle Fire device, and select the option that allows you to view the contents and data stored on the Kindle Fire.
3 Copy or move the Kindle Fire files you want backed up over to your computer's desktop or other location.
4 Right-click on the icon for your Kindle Fire located on your computer's desktop, and select "Remove" or "Eject."
5 Remove the micro-USB cable from your Kindle Fire. After you reset your Kindle Fire, you can follow these same steps to move your saved files back to the Kindle Fire from your computer.
Part 2 Reset the Kindle Fire
1 Tap on the "Quick Settings" icon on your Kindle Fire. The icon is shaped like a wheel, and is located in the status bar at the top of your Kindle Fire.
2 Tap on "More."
3 Tap on "Device."
4 Tap on "Reset to Factory Defaults."
5 Tap on "Erase Everything." Your Kindle Fire will reboot, and display a message that confirms the reset process.
When the Kindle Fire has finished resetting, it will reboot once again, and display the initial start-up screen.
Oct 02, 2014 | Tablets & eReaders
View portrait screen
Tap the settings icon that looks like a gear in the top right corner of the screen and there should be an option to lock and unlock the screen orientation.
Sep 25, 2014 | Amazon Kindle Fire HD
Reset a kindle to factory settings
Two step process, first step we will Deregister your Amazon account and then we will reset the device.
Step 1: Status Bar More + select Account - Deregister
Step 2: Status Bar More + Select Device - Reset to Factory Defaults
Mar 23, 2013 | Amazon Kindle Fire HD
Why cant i use my kindle when pluged into my computer, am i thick
When you connect your Kindle to a PC, it automatically goes to USB mode, allowing access to its internal memory from the PC. The Kindle cannot display a book for reading at the same time. It would require quite complicated handling, for example, to display a book while the book is deleted by the PC concurrently. Allowing only one machine access to the internal memory at a time avoids any concurrency issues.
If you want to read books while continue charging, on the PC:
  • Windows XP, Windows Vista: find the "Safely Remove Hardware" button in the status bar (right side of the task bar), and select "Eject" for the Kindle device.
  • Windows 7: Open "My Computer", press the right mouse button on the drive icon representing your Kindle's internal memory and select "Eject".
Jan 02, 2011 | Amazon Kindle Wireless Reading Device
Nextbook NEXT2 Touch Screen Android Tablet Logo
574 people viewed this question
Top Nextbook Tablets & eReaders Experts
EKASYS IT SERVICES
EKASYS IT SERVICES
Lawrence Oravetz
Nicola Conroy
Are you a Nextbook Tablet and eReader Expert? Answer questions, earn points and help others
