Question about RC Thunder Tumbler Rc Car
Can I order the front wheels 1 broke when it hit a chair
It's the small wheels
Posted by larry doerr on
When my daughter goes down a ramp the wheelchair tilts forward and the back wheels are off the ground! Why is this happening?
ramp too steep and not made to a safety standard
person too high in chair
person too far forward in chair
front wheels not positioned far enough forward
carer not paying attention to the ramp and possible risks
talk with disability persons equipment retailers as they have a good idea of the risks involved with wheel chairs and can advise you on how to overcome the problem
Jun 21, 2016 | Health & Beauty
Center drive wheels doesn't get traction
I have been using power chairs for over 15 years. I have used or driven many brands/setups. If you're Invacare chair has six wheels that contact the ground all the time, this set up is horrible for anything other than a perfectly flat surface. My old power chair has six wheels, but the two front wheels only touched the ground on uneven surfaces or if the chair pitched forward. In Invacare's defense, their setup provides a smooth ride without pitching forward during fast deceleration. But, the "spring arm" tension on the front wheels is so strong that on uneven surfaces, they tend to lift the chair enough that you can lose traction, especially outdoors in the yard, etc. It is rather difficult to do, especially if you are unable to get down on the ground, but I have jammed small wooden spacers into the gap that opens up when the spring arm is lifted. It is difficult to see and difficult to insert the spacers, but the improvement is drastic. I used a small rectangular block of wood per side, almost 1/4 inch thick, and it raised the front wheels off the ground by about half to 3/4 inch. I used double-sided sticky foam strips to hold the blocks in place, but over time they eventually fall out. Maybe next time I will glue them in place. Hope this helps!
Feb 24, 2014 | Pride Jazzy 614 Hd JAZZY 614HD
Loss of control steering wheel jumps when i hit small bumps
sounds like you got a inner tie rod end that is bad
Dec 05, 2012 | Pontiac Montana Cars & Trucks
How do you raise the metro to make it sit higher off the floor? Is it adjustable
This mnaual wheelchair has dual position rear axles and caster forks to allow seat to floor height changes with no additional components. What this means is that the wheelchair is adjustable in height based upon the position of the front caster wheel axles and rear wheel axles. Raising the axles lowers the chair. Lowering the axle postion raises the chair. If the rear axles of the rear wheels are in the top position you can lower the wheels and raise the chair. Likewise, if the caster axles of the front wheels are in the top hole of the fork then put the wheels and axles in the lower hole to raise the chair. It is easy to accomplish this with basic tools.
If the front and rear wheels are already in the lower holes (the chair is in its highest position) you have another option. This option is a more expensive way to raise the chair by buying 4 new wheels. Lets say for example you have 24" diameter rear wheels. If you purchase new 26" diameter wheels you will raise the chair 1". If you have 6" casters and put on 8" casters this raises the chair 1" in the front. Hope this helps.
Nov 23, 2010 | Everest & Jennings 18" Metro Ic3...
My mother-in-law has a jazzy 113 for about 6-7 years and the 2 wheels broke in half. How can this happen when it is a solid wheel? Please let me know what to do. Its the back wheels.
Liz First Did Medicare buy MIL's chair? If they did contact me @ [email protected] and I'll give you more info. Now after that long the tires get brittle and usually need replacement. You can contact the provider where MIL got her chair and have them get the caster wheels for the chair. Hope this helps
Sep 29, 2010 | Pride Jazzy 1113 Power Chair
Motor on left wheel won't work. goes backward a little.
cacheroman If you are not getting a flash code on your joystick like 4 flashes pause 4 flashes then the problem is not with the motor or brake electrically but you have a gearbox problem. I don't remember if on that jazzy if you can order just a gearbox or you have to order the motor/gearbox assembly. Now if Medicare paid for your chair then they will pay for most of the repair cost. You can contact the provider that sold the chair or a service company that has techs to come out and repair your chair. Call Repair Xpress @ 1-877-581-3733 or Roadrunner Mobility @ 1-800-467-2668 and see if they can help you Hope this helps
Sep 26, 2010 | Pride Jazzy 1103 Ultra Standard Power...
After sitting in driveway, back wheels have completely locked up.
Chock the front tires, loosen up the lug nutes on the rear tires, jack the rear end up, uncap the adjuster dust caps on the back of the rear drums, either use a brake spoon or straight blade screwdriver and turn the star adjuster while spinning the wheel until you have no resistance. If this does not work remove the rear tires and hit the sides of the drums with a small sledge hammer or hammer to loosen & break up the rust, When you get movement on the drum, hit it betweeen the studs. Be patient, this may take some time.
Jun 20, 2009 | 1998 Dodge Caravan
RC Thunder Tumbler Rc Car Logo
98 people viewed this question
Top RC Toys Experts
Tom Chichester
 Mikey
Mikey
ray gallant
Are you a RC Toy Expert? Answer questions, earn points and help others
