Question about Toshiba Encore 2 WT10-A32M Signature Edition Tablet
Encore 2 tablet won't boot to windows after trying to reset to factory settings. the tablet was running windows 8.1 when I bought it but I ugraded it to windows 10 a few months ago.
The tablet was running windows 8.1 when I bought it. I upgraded it to windows 10. I tried to reset it to factory settings and now it won't boot up in windows. When it comes up it get to the "Let's get some things out of the way screen" and locks up.
Posted by Steve Shambour on
2 Related Answers
Anonymous
SOURCE: how to factory reset toshiba thrive tablet. can't get past log on due to previous owners lock, unlock password
taking the battery out will do it
Posted on May 06, 2012
White Zombie
  • 4961 Answers
SOURCE: error 0x80070002
You have a virus/malware infestation. Bring it to a repair shop and let the pros fix it.
Posted on Jul 23, 2012
Returning tablet. How do I erase everything and restore factory reset???
hi Deanna.
this is all i could find.
  1. Power off your Tablet.
  2. Press and hold Volume up and Power button at the same time until you boot into the Android system recovery. ...
  3. Choose Wipe data/Factory Reset with your volume keys and then press the power button to confirm.
More items...
Perform a factory reset on Android Device - VisiHow
visihow.com/Perform_a_factory_reset_on_Android_Device
How do you reset a Windows tablet?Reset from within WindowsPlug in your Surface so you don't run out of power during the refresh.Swipe in from the right edge of the screen, and select Settings > Change PC settings.Select Update and recovery > Recovery.Under Remove everything and reinstall Windows, select Get started > Next.More items...Refresh or reset Surface RT or Surface 2 - Microsoft Supporthttps://support.microsoft.com/en-us/help/.../surface-refresh-or-reset-surface-rt-or-surface...Search for: How do you reset a Windows tablet?
How do you do a hard reset on a Samsung tablet?Method 1: From StartupWith the device off, press and hold the "Volume Up", "Home", and "Power" buttons.Release the buttons when you see the recovery screen and the Samsung logo.Use the volume buttons to navigate the menu and select "wipe data / factory reset". ...On the next screen, press "Volume Up" to continue.Samsung Galaxy Tab 4: Steps For Hard Reset - Technipageshttps://www.technipages.com/galaxy-tab-4-hard-resetSearch for: How do you do a hard reset on a Samsung tablet?
How do you restore a Galaxy tablet to factory settings?In fact, consider finding support before you start the following process:Start the Settings app, found in the Apps Menu.Choose Privacy.Choose Factory Data Reset.Touch the Reset Tablet button.Touch the Erase Everything button to confirm. All the information you've set or stored on the Samsung Galaxy Tab is purged.How to Reset the Samsung Galaxy Tab to Factory Settings - dummieswww.dummies.com/...galaxy.../how-to-reset-the-samsung-galaxy-tab-to-factory-settings/Search for: How do you restore a Galaxy tablet to factory settings?
if none of the above work go to this link might help you out more.
tablet factory reset Google Search
1helpful
Says "no bootable device" and its locked up and wont restart
Tablets
I am typing this on a Toshiba Thrive so I am sending you to where I go for answers. In case the link does not work do a search for "Toshiba Forums"
How to reset to factory settings on Tesco connect tablet
Your tablet runs Window 8.1, I believe. Provided it boots up, it's pretty easy to reset it to factory specs.
1) Slide out the Charms
2) Click on the Settings Charms icon
3) Click on PC Settings
4) Click on Update and Recovery
5) Click on Recovery.
6) Choose one of the three options.
If it's not booting up, I don't know what to do other than try how Androids do it by. Pushing and holding the power button and the volume(-) buttons at the same time until a reset screen comes up.
Note 8 still freezes on startup screen after factory reset
you should call to company where you have bought or even better to go in with it
My tablet wont stay on i tried over and over
First try for a factory data reset.
if still the problem persists. it s an Hardware problem
contact authorised service center
To reset you tablet manually. you have to
1)switch of your tablet
2)hold volume down button and power button at the same time.
3)wait for 10 sec and you will enter into boot menu.
4)there in the boot menu you will find option named Reset factory default settings/reset user data. select that option
5) wait for resetting......
6)cheers your done.
2helpful
I turned the talkback feature on and now im locked out of my tablet and i can't type in my pin code
Just make a factory data reset.
6)cheers your done.
Toshiba Encore 2 WT10-A32M Signature Edition Tablet Logo
Top Toshiba Tablets & eReaders Experts
k24674
Ekse
Are you a Toshiba Tablet and eReader Expert? Answer questions, earn points and help others
