Question about Reddy Heater-30-55,000 BTU Variable
Why doesn't it light sometimes? - Reddy Heater-30-55,000 BTU Variable
Posted by Danny on
I have a 2008 Chevy Trailblazer. Problem started with the air conditioner blowing hot air and when it does this, I noticed the temperature gauge doesn't register anything.
Hi Christy.
It sounds like your BCM, (Body Control Module) is failing, or your Connector/Connectors to your BCM could be at fault. They could be corroded, Damaged, burned, loose, and/or could possibly have bad wires on or going to the connectors. I would take it to a mechanic that you trust and have them check it for you. Do you have a check engine light on? Hope this helps.
Nov 04, 2016 | 2008 Chevrolet Trailblazer
Seems to have a bad connection...
take a OBD2 scanner to have check, maybe you will know what is problem.
car diagnostic tools
Jul 29, 2013 | Razor USA Razor Dirt Quad Electric ATV
1998 Chevrolet C3500 dies randomly when driving down the road - uphill, downhill or flat surfaces. Typically doesn't happen when it's cold. Sometimes it starts back up and sometimes it doesn&#
my younger brothers' truck did the same thing and there was a relay up under the dashboard that would get hot and shut of(kind of a circuit breaker unit) most of the operating systems will flash at you when only battery voltage is available which explains the lights coming on..these newer trucks also have a performance chip in the system that will act up when it gets warm also..replace this and you may be ok..let me know what happens also.. good luck.
Jan 16, 2013 | Cars & Trucks
Warning doesn't ding when lights are on and key fob only unlocks some time
1) Try the other fob.
2) Driver door latch mechanism needs repair/replacement.
Jul 15, 2017 | 2005 Volkswagen Jetta
Erratic key fob effectiveness. sometimes the door lock seems weak when it unlocks. other times it works great. sometimes it doesn't open at all. I've replaced the battery in the fob. The light...
What make , model , year vehicle ? Maybe fob needs to be replaced or the receiver part . Could have DTC'S - diagnostic trouble codes stored in the BCM - body control module .
Feb 21, 2018 | Cars & Trucks
Heater doesn,t work. Controls on dash sometimes light up & sometimes doesn,t. All of my fuses are good. It seems to act up mostly in the morning. Sometimes if I turn my head lights on my gauges quit...
Morning Charlie,
If it were me, I would check the wires coming & going to & from engine. Maybe something is crossed. That's what it sounds like, anyways.
Oct 08, 2010 | 1996 Jeep Cherokee
Reddy Heater-30-55,000 BTU Variable Logo
124 people viewed this question
Top Reddy Heating & Cooling Experts
Paul Carew
Marvin
Marvin
Fahr Quad
Are you a Reddy Heating and Cooling Expert? Answer questions, earn points and help others
