Http://www.canon.co.uk/support/consumer_products/product_ranges/printers/pixma/error_codes/#b200
B200 Error- This could also be displayed as P10 or the orange and green light blinking 10 times
Description:
B200 is a service error that can occur due to a hardware failure with either the printer or the print head.
Resolution:
In most instances, a B200 error will require a repair at a Canon authorised repair centre, however prior to sending your printer for repair please follow the steps below to try and resolve this error-
If the error message is still showing, then it is necessary to deliver or send the printer to an authorised repair centre.
If the printer is still under warranty, (generally one year from purchase) and supporting documentation is provided, then a free of charge warranty repair will be carried out.
If the warranty has expired, then any repairs can only be carried out at cost and charges will apply.
You can find the details of your nearest repair centre using our interactive repair centre locator.
If you own a PIXMA PRO-1 please contact us directly as you may be eligible for an on-site repair.
SOURCE: Error Code B200 on Canon Pixma IP4300
Just restart the system and turn off the printer and turn on the printer it will work.
Check did you correctly placed your cartidges.
SOURCE: does not print error b200
Helo, found on web. Good Luck :0)
The error code is standard for many of the late model MPxxx printers. The B200 error is "Printhead Temperature exceeded", What this means that while you were printing some document, either one or more of the printhead ink wells ran out of ink and the printing continued. Printhing without ink in the wells will OVERHEAT THE PRINTHEAD NOZZLES and can potentially burn the out. The printer has a built in temperature sensor to detect the ambient temperature and to monitor the temperature of the head. This data is always collected and monitored and saved in the EEprom data and the Service Test print data.
If the error will not go away once you have unplugged the priner for at least 5 minutes, then there is the possibility that you have already burnt out the head. Remove the printhead and use a 5x magnification glass to look VERY CLOSE at all of the nozzles to see if you can detect any possible burnt out nozzle.
It many come down to need a new printhead.
HERE IS THE LINK, IF YOU HAVE PROBLEMS.
http://www.fixyourownprinter.com/forums/laser/13864
SOURCE: What is service error B200?
According to Canon's documentation, this is simply listed as a printer error (not very descriptive). It is likely a hardware fault on a board; a physical hardware malfunction.
This is Canon's official stance on the error:
Turn off the machine, and unplug the power cord of the machine from
the power supply.
If the problem is not resolved, contact your Canon service
representative.
After looking a bit more, I discovered that the B200 error is a Voltage High Error on the iP4500 chip. Try calling Canon tech support at 1-800-828-4040. If your printer is still under warranty, they will probably send you a
new printhead or a new printer.
SOURCE: canon pixma MP480 printer error code B200. What is B200?
Try keeping the paper only in the bottom tray (there's a tray in the bottom) Try pulling any paper out of the top and just close that top tray. Open up the head so that u can see the ink cartridges and turn the printer on and off and maybe it will center itself again. If it's still not working (even if lights aren't red and print head wont align in the center) try manually moving the head back and forth like 18 times so you can lubricate that rail in the back that's holding it. After that, re-turn it off and on again.
SOURCE: Canon MP510 printer not printing error message B200 -
ERREUR B200 SUR IMPRIMANTE CANON PIXMA MP 510
