Car Audio & Video Logo
Question about Kicker Car Audio & Video
A kicker 600.1 wired to a jl w7 10" sub? Will that work?
Posted by Jonluton on
Tyler King
    New Friend:
  • 4 Answers
The kicker 600.1 provides 600 watts at 2 ohms and 300 watts at 4 ohms the 10" JL W7 has 2 1.5 ohm voice coils so you will have to wire them in series. Take about 1.5 feet of 14 gauge wire and connect the positive of one voice coil to the negative of the other then the positive and negative that are left go to the amp. Your impedance should be 3 ohms and that amp should work just fine.
Posted on Jan 24, 2016
5 Related Answers
Anonymous
  • 111 Answers
SOURCE: subwoofer wiring diagram
parallel wiring. hook all 4 positives together and run to the positive output from the amp, hook all 4 negatives together and run to the negative output from the amp.
hope this helps,
trin
Posted on Nov 19, 2007
Anonymous
SOURCE: kicker solobaric l5 12''
how to wire a kicker solo baric l5 12'' 4ohm down 2 and 1 ohm
Posted on Feb 03, 2008
Anonymous
  • 185 Answers
SOURCE: one of 2 subs stopped working.
ya the sub is blown or the amp channel is blown
Posted on Apr 10, 2008
Anonymous
SOURCE: how do you wire up the voice coils on the w3 subs i have 4 jl 15s
Hi their the best link ever to wire up subs is this:
http://www.crutchfield.com/S-s8dIAxJtgx2/learn/learningcenter/car/subwoofers_wiring.html
Posted on Apr 10, 2009
Anonymous
  • 3 Answers
SOURCE: show me how to connect my wires on my kicker l7
Are you using a cross over?
Posted on May 22, 2009
It just stopped working after about 4 years. the amp went in and out a couple of times then it just stopped working.
ok what type of amp are we talking about, what impedence and voice coils are your subs, and have you checked power, ground, fuses, etc... a quality amplifier kicker, jl, mtx, rockford... etc... should, if set up and wired properly, last you a very long time... I actually had a kicker amp since 96 and it still worked great to the day i gave it to my buddy... That's 11 years old with no issues...
I want to know the best subwoofer wiring diagram for three kicker cvr 10 inch subs, 2 of them are dvc 4 ohm and 1 is dvc 2 ohm, the amp that i am using is jl audio 500.1 1.5-4ohms stable. can anyone help...
if the amp has a 2 outputs then i would wire the two 4ohms together, and the 2ohm by itself. and if its a 4 channel output then wire them all sepretly, if its a 1 channel output then wire the two 4ohms together and leave the 2ohm sub out
I wonder if i get two kicker cvx 10 can be push by jl audio 500.1
It can but it'd be a waste for your subs. 1 of those by itself will handle that amp. it'll push them just not really hard, i'd recommend an upgrade to a 1100-1200 watt rms amp if you're gonna run 2 cvx's. if you only run one sub that amp'll work well...
Got jl300/2 amp confused which subwoofer sounds good
Hello drsubhakar26,
JL W6's will perform well with from 150-600 watts RMS. W7's with from 150-500 watts. Less expensive Alpine Type R's work OK with from 200-500 watts RMS. Either of the brands will sound good. None of them will perform to their full potential with 300 watts RMS. Powering any sub with a 2-channel amp is a compromise. A monoblock is more efficient.
Hope this helps.
2 L5 12'S 2OHM
I like JL Audio's products and in this case a 1000/1 would match these subs really well considering that each sub is rated at 600 watts RMS. I know that you want to bring these subs to the max and if you're not worried about blowing them up you can use two JL Audio 1000/1's, the JL amps have something called ohm matching and can put out 1000watts RMS at any load between 2ohms and 16ohms. A very use full feature - as well as a subsonic filter that can keep out the bass you can't hear and thus keep your subs alive longer especially if you plan to max em' out. Check out Ebay for good prices on JL Audio. Another choice might be an Audiobahn 2300, or preferably an 1800d. D class amps are best for max output and I've wired an Audiobahn 1800d down to a 1 ohm load (to two dual 4 ohm 15" Cerwin Vega Strokers paralleled down) and it was able to stay alive, but this was not used for prolonged listening (Short bursts for SPL comps). Good luck and I'll leave you with an old trick I used to use on my clients SPL Comp cars. Run an in-line fuse to each sub - start at about a 100amp fuse (1,000w @ 12v = 120 amp draw) and move it up if it blows too early, fuses are cheaper than subs! Let me know what box you are running as it must be built specifically for running the subs all-out. You can e-mail me @ ([email protected]) for free specs on basic enlosures.
-Dynami
1helpful
Kickers dont beat like they should
try to check and clean the wiring as clean as possible to avoid messing up on your connection. Check the polarity of you subs to yuor amp if you have it connected on the outher way around it would not give you a good result. check the polarity this will solve your problem. Over powering your sub will fry it easily try to tune it a 10" sub wont give you a 15" performance..
Subs dont beat like they should
you've spent alot of money on **** by the sounds of it!!. you should only ever run multiple subs the same brand, power and resistance you can just connect any old subs to a system you need to wire them depending on the load that the amp needs to see. first thing is to try the amp/s on a individual sub to check your amps still work once done check the subs 1 by 1.
Clarification for jl amp problem
sounds very much like resistance was an issue and no they dont have an internal fuse sorry
500/1 v2 and one kicker VS12L7
It will work fine. This amp is stable to 1.5 Ohms, but is designed to put out about the same amount of power at 2 or 4 Ohms (unique).
Jl sub not powering on
ok try your sub on another amp is first find out if that works or not if it works then there's a good chance you amp is knackered
Top Kicker Car Audio & Video Experts
Morne Olivier
Morne Olivier
Marvin
Marvin
Steve Sweetleaf
Steve Sweetleaf
Are you a Kicker Car Audio and Video Expert? Answer questions, earn points and help others
