Question about Sewing Machines
Is it possible to change the fuse in a sewing machine?
The machine didn't turn on when I switched on the power. There seems to be no power getting to any part of the machine. I have checked my power supply and the cord and plug seem okay.
Posted by Maureen Watts on
R.A. Ellis
  • Sewing Machines Master
  • 12,731 Answers
Is the light working? If not, it is probably an electrical problem.
Some machines have batteries, so it could be logical that there could also be fuses. From the problem you are experiencing, I would suspect your problem lies in the foot control unit. Most of them have brushes that get worn down. When they are worn too much, they fail to make contact and there is no longer power to the machine. Brushes can be replaced by the adventurous and mechanically inclined. The motor can also have brushes with the same problem.
Take to a sewing repair service or search the internet for sites and videos on replacing brushes.
Posted on Jan 14, 2016
J.D. Browning
  • 2,760 Answers
The only fuses ive ever seen inside a sewing machine was located inside the foot switch assembly and ive taken apart a few dozen now , but now ive seen quite a few broken power cords and sockets in that few dozen , seems the power cords sure take a beating on these ?
Motor won't run.
The problem could be with the switch that powers the motor or the brushes on the motor itself may be worn. Also look for bad connection in the wiring.
Sep 17, 2017 | Husqvarna Huskylock Computerized 910
The thread isnt moving with the sewing machine
is it possible that you didn't get the needle inserted all the way into
the needle holder?
is it possible that the needle is not turned the right way in the
needle holder?
Oct 27, 2012 | White Sewing Sew Cute SC20 Mechanical...
Curvy 8770 won't turn on
here's a link for a free manual
http://www.singerco.com/uploads/download/1199_8770-efs.pdf
I had other questions about the singer curvy,, check in the manual
to see if it has a hidden fuse.
if it doens't have a fuse, the it could be the power cord or the
on & off switch
Sep 27, 2012 | Singer Curvy 8770 Electronic Sewing...
Sewing Machine froze up
it's very possible that the machine jumped time,even tho the needle didn't
break, it's possible that the needle bent.
the machine needs to be retimed at a sewing machine shop.
Apr 26, 2012 | Brother Sewing Machines
Janome 9000 lost all power in the middle of embroidery and won't turn back on.
have you checked to make sure the power cord is plugged into the machine correctly?
is the outlet getting electricity?
if the answer to the above is yes
then it's possible the power cord, motor could have with out
have you checked to see if the sewing machine has a battery compartment
or a fuse compartment?
Mar 29, 2012 | Janome Memory Craft 9000 Computerized...
The belt needs to be replaced on euro-pro sewing machine. How do I get it off?
it is possible that it could be the belt, but it's also possible that it could be the power cord or foot pedal,, only a sewing machine repair shop can tell which it is
Jan 18, 2012 | Euro-Pro 9000 Mechanical Sewing Machine
I have a Bernina 170 which I haven't used in about 2 years. I just tried to set it up and it won't turn on - are there any fuses or anything I can check myself before having to haul it to a repair shop>
The only fuse you can get at is in the plug, I'm afraid. There is a fuse on the power-supply circuit-board, but you do need to dismantle the machine to get at it and it is not the type used in a normal plug, so has to be replaced by the correct type if it is blown. You're best to have it checked professionally - it may be something quite simple. I am assuming that absolutley nothing happens --- not even the sewing light? There is a known problem with the switches on these power supplies and if you have an early one, it may be possible that if this is the fault you can just get the switch changed, but unfortunatley not all service agents will do this and it depends on the state of your machine warranty.
Nov 25, 2009 | Bernina Artista 170
Machine died
Possibly like my Bernina. Needs new on/off switch.
Jul 29, 2008 | Sewing Machines
Serger not getting power
First the basic tests....
The cable is securely inserted to wall and machine and both switched on ?
Have you tried a different socket and tried something you know works in the one you want to sew from ?
If the socket is OK, then it would be a good idea to have it seen to by someone qualified........it may just be a fuse, but it may be more serious, and as this is electricity, not to be messed with I suggest.
May 14, 2008 | White Sewing Speedylock 1600 Mechanical...
Sewing Machines Logo
49 people viewed this question
Top Sewing Machines Experts
Chris Wetmore
Marvin
Marvin
Are you a Sewing Machine Expert? Answer questions, earn points and help others
