Question about Pioneer AVIC-U260 Add-on Navigation Unit for All 2012
This unit motorhome with a avhx2700 radio unit. we have a very distorted navigation screen got any suggestions
Posted by marissa rivenburg on
Claude Kayser
    Top Expert:
  • Pioneer Master
  • 9,098 Answers
[PDF]AVIC-U260 - Pioneer
https://www.pioneerelectronics.com/.../AVIC-U260+O... Pioneer CorporationPIONEER AVIC-U260 - for Canada 8. - END USER .... ing or distortion and, most importantly, with- ...... After a short pause, the navigation screen ap- pears.
AVH-X5700BHS - DVD Receiver with 7" Motorized ... - Pioneer
www.pioneerelectronics.com/.../AVH-X5700BHS
Pioneer CorporationFeb 16, 2015 - For more information, visit pioneerelectronics.com/AppRadioOne ....Easily upgrade to navigation with the addition of the AVIC-U260 add-on ...
GPS Navigation ' Pioneer Electronics USA
www.pioneerelectronics.com/PUSA/.../GPS-Navigati...
Pioneer CorporationCar Navigation Systems products with built in bluetooth handsfree technology. Includes dvd gps navigation: in-dash and portable. ... AVIC FEEDS App.
Posted on Jan 13, 2016
Need serial number of a pioneer radio in a Forest River FR3 Motorhome? Just bought it used?? Help??
If dash radio wont come on make sure disconnect on at house for serial check in packet of manuals should be on radio manual if you don't have remove radio its on unit
Feb 22, 2018 | RVs
Infinit m35 navigation system cutting out
Without knowing too much about this particular unit, I'll make one suggestion. When it does work, see if you can find a reset option in your setup options.
Apr 08, 2017 | 2007 Infiniti M35 Sedan
Have a 2003 navigator, my youch screen on my radio/ navigation etc went dark, the screen completely still work's but cant see anything...any suggestions?
Check the display settings, try resetting your nav to factory settings if that didn't help, you have to visit the dealer due to programing issue or software issue.
good luck
Oct 04, 2011 | 2003 Lincoln Navigator
I am getting Power (fuses ok) to my Radio and Navigation on my 2006 Sienna but the power button will not work so no sound or Navigation screen? What could be wrong? Thanks
Check to make sure all fuse associate to the radio/navigation is good, sometime like the acc socket fuse being blown could cause the thing to not work also, so make sure you get to all the fuse to make sure they are not blown. After that, there maybe a fuse located with the navigation unit behind the radio/navigation unit that may be blown. If there isn't or is still good, check all connection to it. If all is good then your unit could be history and you may need to take it to a dealship to actaully see what is going on.
Jan 30, 2011 | 2006 Toyota Sienna
I have recently purchased a G1301E unit. Upon installing the unit in my Fiat Ducato 2.8 Diesel Motorhome, everything works OK apart from as soon as I start the engine I loose all sound, no music from the...
You may have got the wiring wrong for the Power
it has one power and one for connecting to headlight power Which when headlights on it will illuminate the radio more/less depending on manufacture.
Mixing these up could mean soon as you start its thinking it needs to dim screen but instead its dimming the power.
Aug 11, 2010 | Car Audio & Video
Jensen VR187 radio/backup camera observation monitor won't work
In the manual look on page 10 step 10. You have to use a ball point pen and straightened paper clip (better) to reset the unit. There is a small hole at the lower left of the Volume knob. That's where you insert the paper clip.
Aug 09, 2009 | Audiovox Jensen JTFT-250 2.5 in. Handheld...
DVD player car screen plays dvd in B/W , navigation in color
try checking the color system if its ntsc or pal
Jul 11, 2009 | Car Audio & Video
I have a 2007 chevy trailblazer with a factory touch screen navigation and xm radio. I have contacted XM for their subscription and they have on several times tried to reset or resend the signal to my...
All i can really suggest is let GM check it out if they want to replace it, i would look into replacing it with a upgraded after market unit to fit in its spot. probably cheaper than dealer will charge.
Nov 27, 2008 | Car Audio & Video
Mk4 head unit not working
Hello There.
Thats an interesting one. My first suggestion would be to look at the DVD navigation unit in the trunk, does it have any sign of life, i.e will it eject the map dvd is there a blinking redlight etc, if there is nothing then thats most likely your problem if there life in it then I would suggest having a closer look at all the connections in the trunk. You need to remove the side cover in the trunk and check the connections.
If the above doesn't help, my guess would be your head unit has the fault.
The cheapest way to get this repaired is by process of elimination. If you think the DVD unit in the trunk is faulty I would buy one from ebay if you find this doesn't solve your problem you can always resell it on ebay without losing money and the same with your head unit.
Hope this helps. Good Luck.
If my answer has helped you, please rate me on Fixya.
Many Thanks.
ILikeBMW
Nov 12, 2008 | 2003 BMW 330
Can't get past navigator loading screen any suggestions? it's a Nav-Cam 2007
it sounds like a defective unit, but it may just be a corrupted SD card.
Aug 14, 2008 | Evesham Nav-Cam 7700 GPS Receiver
Pioneer AVIC-U260 Add-on Navigation Unit for All 2012 Logo
282 people viewed this question
Top Pioneer Car Audio & Video Experts
Marvin
Marvin
Jeffrey Turcotte
Jeffrey Turcotte
Are you a Pioneer Car Audio and Video Expert? Answer questions, earn points and help others
