Question about Hisense Televison & Video
How to set up a hisense tv to watch all the channels
rugby prop
    Master:
  • 595 Answers
Normally you have to go to menu, then something like tuning for digital recievers, then select auto tune. The tv should then try to find all the available channels, note this will take several minutes
Posted on Jan 13, 2016
How do you turn up the volume on hisense ledn32d33 without a remote
See if the set has volume controls on it. Some sets have a power switch and volume/channel controls on them.
May 29, 2016 | Hisense Televison & Video
How to a get a full screen on a Hisense H5 smart TV
Full screen is a function of the program you're watching. Some programs will never fill the screen completely because of the way the program was originally formatted. Example: You watch an older movie that was formatted for 4:3 aspect ratio. It is impossible to watch the movie full screen in it's native mode. It makes no difference if you're watching the program off a DVD or a cable channel. You can rty filling the screen with the stretch and zoom functioms on the TV, but you will have to live with a distorted picture or loose a lot of the program picture because zoom cuts off a lot.
Dec 02, 2015 | Hisense Televison & Video
Hi, we have a Hisense 55inch, full hd LCD tv. We have not been able to access free to air channels for some time now. We have foxtel and have still been able to watch this on the tv without issue. It just...
hi it's possible you could have a faulty tuner on the tv, check the aerial connection on the back of the tv pinch the center pin together not to much pressure thanks
shaun
Mar 23, 2017 | Televison & Video
Hisense TV is too loud on the lowest setting Why?
Enter its sound settings, and reduce the amplitude to 'Treble" setting.
Aug 13, 2014 | Hisense H3 Series - 32" Class 31-1/2"...
Loss of sound
you can try changing the assigned channel.you should have to put the second T V on a certain channel like channel 72 or 68 or something like that.on the main reveiver you should go into the menu and poke around in the setting until you see a REMOTE ADDRESS option walk through the steps and change the channel that the second TV receives its picture on, you should shoot for channel 62-72.also make sure the hisense is set to a cable input.you can go into the menu on the hisense and go to your settings and change this .it will be on CABLE or ANTENNA.try switching those around.also did you have sound before coming out of the coax output on the hisense? if your not sure then plug a vcr into and make sure the TV is working with different equipment.GOOD LUCK!
Nov 08, 2007 | RCA DISH Network(r) 311 Satellite System
Hisense TL2020 TV repairing
To unlock your Tl2020 with a universal remote just go into the menu and select V chip setting. The password from the factory is four zeros (0 0 0 0 ). Once you get in you will the letter "B" nect to everything. Set everything to the letter "U". Then, turn off the television. The set should be unlocked now. Good luck !
Frank
Sep 15, 2007 | Hisense TL1700 17 in. LCD Television
Televison & Video Logo
275 people viewed this question
Top Hisense Televison & Video Experts
David Tickner
Marvin
Marvin
Are you a Hisense Televison and Video Expert? Answer questions, earn points and help others
