Cars & Trucks Logo
Tansu Uslu Posted on Jan 13, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
2007 jeep grand cherokee park assist system and display panel power switch does not work , the lights do not illuminate . What could be the problem and how to solve ?
_-__-___-_
Level 3:
  • Jeep Master 20,706 Answers
  • Posted on Jan 13, 2016
_-__-___-_
Jeep Master
Level 3:
Answers
20706
Questions
Helped
6803968
Points
57965
Check fuses
then pray. pray its not a dealer only fix.
2008 Jeep Grand Cherokee; which fuse controls heater and a/c dashboard lights please?
Question edited to toss in some CAPS.
Question moved to model category.
Jeep Grand Cherokee (WK; 2005-2010) fuses and relays
https://fuse-box.info > jeep > jeep-grand-cherokee-wk-...
Here you will find fuse box diagrams of Jeep Grand Cherokee 2005, 2006, 2007, 2008, 2009 and 2010, get information about the location of the fuse panels ...
2008 Jeep Grand Cherokee fuse box diagram - StartMyCar
https://www.startmycar.com > ... > Fuse box
The 2008 Jeep Grand Cherokee has 3 different fuse boxes: ... Jeep Grand Cherokee fuse box diagrams change across years, pick the right year of your vehicle:.
2005-2010 Jeep Grand Cherokee WK Fuse Box Diagram
https://knigaproavto.ru > ... > Jeep > Grand Cherokee
Oct 7, 2019 - Fuse Box Layout Jeep Grand Cherokee; engine: 3.0L Deisel, 3.7L, 4.7L, 5.7L and 6.1L (WK; 2004, 2005, 2006, 2007, 2008, 2009, 2010)
97 jeep grand cherokee ltd 5.2l trans not going into gear
power and eco modes?
about lights out issue:
dash lights and all other interrior lights connected to fuses inside fuse box. fuse is blown.
please check fuses #7 #16 and #17 (cluster, courtesy lamp,radio illumination)
5helpful
I have parking sensors on my 2006 jeep grand cherokee front and back. they do not work any more. the computer is telling me to service them. how? I do have two red lights on the displays and i can't...
When you put your jeep into reverse you will see the red lights. These will still work even when is says service parking assist system needs service. The problem is in your transmission control unit. This is a common problem in the Grand Cherokees. You will have two options here. You can take it to your Jeep dealership and ask them to flash the TCU. This may or may not work. The other option is they will have to replace the TCU. They run about $600.00. Hopefully if they flash the TCU it will work again. Good luck
1helpful
2answers
How to disarm or reset an alarm system for a 1996 Jeep Cherokee?
Hope this helps:- Factory Disarm Purple/Yellow (-) Driver's Kick Panel Black Connector at ECM -slice into this wire, & wire it to ground, this disables the alarm.
Cavity/Fuse Diagram (1996 Grand Cherokee, passenger side kick plate to find, Owner's Manual pgs 205-206): 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22
Row 1: 1-6 (left to right) Row 2: 7-12 Row 3: 13-18 Row 4: 19-22
1996 Jeep Grand Cherokee Fuse Panel (Passenger Side kick panel) Reply
CAVITY FUSE DESCRIPTION 1 -10 amp (RED) Radio 2 -15 amp (Lt Blue) Cigarette Lighter 3 -10 amp (RED) Rear Washer Switch, Body Controller 4 -10 amp (RED) Airbag 5 -10 amp (RED) Lamp Out Module, Overdrive Switch, OBD II 6 -15 amp (Lt Blue) Vehicle Information Center/Graphic Display Module Park & Side Lamps, Overhead Console Lighted Visor, Automatic Dimming Mirror 7 -20 amp (Yellow) Body Amp, Cluster, Body Controller 8 -20 amp (Yellow) Rear Wiper Motor, Flipper Glass Solenoid, Cargo Lamp, Trailer Tow 9 -15 amp (Lt Blue) Brake Switch 10- 10 amp (RED) Rear Window Defroster 11 -10 amp (RED) ABS Module 12 -10 amp (RED) Heater-Ventilation-A/C Control & Recirculation Motor 13 -15 amp (Lt Blue) Hazard Switch, Turn Signal Switch 14 -15 amp (Lt Blue) Spare 15 -15 amp (Lt Blue) Spare 16 -10 amp (RED) Right & Left Courtesy Lamp, Glove Box Lamp, Halo Lamp Cargo Lamp, Underhood Lamp, Dome/Read Lamp Right & Left Visor, Automatic Dimming Mirror 17 -15 amp (Lt Blue) Radio Illumination, Tail Lamp, Graphic Display Module, Park & Side Lamps, Headlamp Switch, Body Controller 18 -20 amp (Yellow) Spare 19 -15 amp (Lt Blue) Passing Light 20 -15 amp (Lt Blue) Radio, Heater-Ventilation-A/C, Vehicle Information Center 21 -15 amp (Lt Blue) Power Outlet 22 -10 amp (Blue) Airbag Module -------------------------------------------------------------------------------------
1996 Jeep Grand Cherokee Alarm, Remote Starter, Keyless Entry Wiring Information Constant 12V+ Pink/Black Ignition Switch Harness Starter Yellow Ignition Switch Harness Ignition Dark Blue/Gray Ignition Switch Harness Ignition 2 Red/Black Ignition Switch Harness (for AC) Accessory Black/Orange Ignition Switch Harness Tach Gray/White Coil Brake Switch White/Tan Brake Switch Trunk Pin n/a Works with Dome Light Parking Lights Blue/Red (+) Left of Steering Column or Light Switch Head Lamp Tan/Black Light Switch Factory Disarm Purple/Yellow (-) Driver's Kick Panel Black Connector at ECM -slice into this wire, & wire it to ground, this disables the alarm. Door Trigger Yellow (-) Driver's Kick Panel see notes Door Lock 5/Wire in Driver's Inside Driver's Door Orange/Purple Lock Pink/Black Unlock Door Unlock and Passenger's Doors Inside Passenger's Door Black/White L Pink/Black Unlock Horn Wire Gray/Orange (-) Steering Column Windows Up LF=Light Blue, RF=Brown/White, LR=Blue/White, RR=Gray/Black Doors Windows Down LF=White, RF=Purple/White, LR=Red/Black, RR=Green/White
• Cruise Control Information • Stereo Information • View all Jeep Vehicles
3helpful
2answers
I have a 1996 Jeep Cherokee and the heater vents dont work.I have tried to find a picture of the fuse panel i can read but i cant..When you swith it to vents it only comes out of the defrost.Where can i...
Hope this helps:
1996 Jeep Grand Cherokee Alarm, Remote Starter, Keyless Entry Wiring Information Constant 12V+ Pink/Black Ignition Switch Harness Starter Yellow Ignition Switch Harness Ignition Dark Blue/Gray Ignition Switch Harness Ignition 2 Red/Black Ignition Switch Harness (for AC) Accessory Black/Orange Ignition Switch Harness Tach Gray/White Coil Brake Switch White/Tan Brake Switch Trunk Pin n/a Works with Dome Light Parking Lights Blue/Red (+) Left of Steering Column or Light Switch Head Lamp Tan/Black Light Switch Factory Disarm Purple/Yellow (-) Driver's Kick Panel Black Connector at ECM Door Trigger Yellow (-) Driver's Kick Panel see notes Door Lock 5/Wire in Driver's Inside Driver's Door Orange/Purple Lock Pink/Black Unlock Door Unlock and Passenger's Doors Inside Passenger's Door Black/White L Pink/Black Unlock Horn Wire Gray/Orange (-) Steering Column Windows Up LF=Light Blue, RF=Brown/White, LR=Blue/White, RR=Gray/Black Doors Windows Down LF=White, RF=Purple/White, LR=Red/Black, RR=Green/White
• Cruise Control Information • Stereo Information • View all Jeep Vehiclesairconman.jpg
I drove the Jeep home with no problems. This morning, it won't start -- no power at all, no radio, light, power lock, power window ... nothing works but I keep on hearing a fast "tick, tick, tick" sound...
Your battery is low or has weak cell. I recommend jump starting vehicle. If it jump starts then replace the battery. If
battery warning light is illuminated on dash may have charging
system concern.
8helpful
94 grand cherokee fuse panel fuse id,,,need to know each fuse function, location in panel and amp
............1994 Jeep Grand Cherokee
......(Fuse Block - Passenger side of Dash)
.....1........5........9........13........17........21........25
..20 A...15 A...20 A....20 A....7.5 A.....15 A....30 A
.....2........6.......10.......14........18........22........26
..15 A...15 A...10 A....20 A.... 15 A.....15 A....30 A
.....3........7.......11.......15........19........23........27
..20 A...15 A...15 A.....3 A......15 A....15 A.....10 A
.....4........8.......12.......16........20........24........28
..15 A...15 A...15 A....20 A.....10 A....7.5 A....30 A
1)Trailer Tow Relay
2)Brake Lamps
3)Hazard Lamps
4)Security Lamp
5)Interior Lighting
6)Security Alarm Module
7)Security Alarm Relay, Security Alarm Module, Flash-to-Pass
8)Overhead Console, Keyless Entry, Radio Memory/Clock
Memory/Chime Module, Power Locks, Power Mirrors,
HEVAC and VIC
9)Rear Wiper
10)Radio
11)Cigar Lighter
12)Parking Lamps, Automatic Headlamps
13)Horn Relay
14)Power Lock Relays
15)ABS Module and Relay
16)Turn Signals
17)Heating and Air Conditioning Module
18)Airbag Module
19)Interior Mirror, Auto Headlamps, Overhead Console,
VIC/GDM Module, Heated Rear Window Relay Coil,
Illuminated Entry Relay and Chime Module
20)Heated Rear Window Switch, Overdrive Switch, Speed Control
21)Security Alarm Module, Lamp Outage Module
22)Airbag Module, Speedometer, Tachometer, Telltales and
Gauges
23)Heated Mirror Feed, Heated Rear Window Switch
24)Instrument Panel Illumination
25)Power Seats
26)Power Windows, Power Sunroof
27)Security Alarm Module and Front Wiper
28)Heated Rear Window Relay
2007 Jeep Grand Cherokee interior lights our
You will get your solution and all info on service info, repair info, parts info, wiring/electrical/fuse diagrams, error/fault codes, torque specs, PCV,
owner's/service/repair/parts/maintenance manuals etc everything
this website www.reliable-store.com
it's a very good website for vehicle problems even as old as 1991 ford..
5helpful
2answers
How do you service park assist system on a grand Cherokee?
I got a 2007 jeep grand cherokee diesel and at times the service park assist will flash and the engine light will come on. a box forms around the gears on the display and it feels like it trannys slipping and its rough out of 1st gear. if you throw it in neutral then back to drive everything is fine again. After hours of research i found that you have to get your computer flashed. It if commom for many people and the dealership wont know what your talking about. so you have to lets them know!!!! else they have no clue
2answers
Dash and shifter lights in 1996 jeep cherokee wont light
Hello and welcome to FixYa . Locate the dial that controls the brightness of the dashboardlights. If the control is not immediately evident. Make sure the brightness control is turned on. If it is and the lights aren't working, the problem may be a bad fuse. Check the fuse that controls the dashboard lights Replace the fuse if necessary. If just one part of the instrument panel is not lighting up, then you have either a burned-out bulb or a wiring problem.
Passenger side kick panel fuse breakdown for a 1996 jeep Cherokee Country
01 - 25A Rear Wiper/Washer
02 - 15A Radio, Cigar Lighter
03 - Empty
04 - 15A Passing Light
05 - 30A Blower Motor
06 - 30A (Circuit Breaker) Power Windows
07 - 02A ABS
08 - 20A Turn Signal Flasher
09 - 10A Radio/Clock Memory, Courtesy Lights, Glove Box, Cargo, Dome Lights, Telltales
10 - Empty
11 - 25A Headlamp Delay Module, Horn
12 - Empty
13 - 20A Power Door Locks
14 - Empty
15 - 15A Instrument Panel Lamps, Clock/Radio and Memory, Headlamp Switch, Parking Lamps
16 - 30A (Circuit Breaker) Power Seats, Trailer Tow
17 - 7.5A Instrument Cluster Gauges, Headlamp Delay Module, Chime Module, Overhead Console
18 - 25A Rear Defrost
19 - 05A Instrument Panel Lamps, Radio Illumination
20 - 5.5A (Circuit Breaker) Windshield Wipers and Washers
This should get you going. And you can always Ask Me.
Top Jeep Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
john h
Are you a Jeep Expert? Answer questions, earn points and help others
