Question about Xerox Phaser Office Equipment & Supplies
Xerox work center 5225 it shows Drum catridge smart kit is fault
I have Xerox work center 5225 photocopier yesterday its waste toner recycle spiral rod was broken & i replaced with a new one after installing the drum catridge, i printed 20 copies it show a problem Drum catridge smart kit is fault i replaced a new drum chip same it work for 30-40 copies after same problem.
Posted by Santosh pattnaik on
NICK FIRTH
    Passionate:
    Visited the website for 10 consecutive days.
  • Xerox Expert
  • 129 Answers
Have you tried replacing the whole drum cartridge?
Posted on Jan 15, 2016
Xerox WC5225 model code showing 093-312 what is the matter
If you wish to get some details; check the site linked here. Pull up older posts...
http://electro-medical.blogspot.com/
Aug 23, 2016 | Xerox Workcentre 5225 Multifunction 11 X...
Xerox 7335 Yellow Drum catridge did not shows.. Catridge is perfect but did'nt shows...
Make sure deal has been removed pull out press cancel 30 seconds...power off on the put back in
Jun 28, 2016 | Miscellaneous
My company have 2 unit photocopier machine model TOSHIBA e-studio 600...now this 2 unit have a same problem (display CD30)..what is the meaning of CD30...could u please help me...
CD30 shows that the waste toner on the recycle unit is full. U need to dispose it. Open the front cover, take out toner drive, take out the 2 covers, and u will see the recycle unit.
May 25, 2011 | Toshiba E-STUDIO 850 Copier
Xerox M15i uneven print and photocopy quality. Center of the page is darker than edges. I have run the clean drum, put in a new toner cartridge.
If the problem appears BOTH by copy and print situations, the problem is the drum unit itself.
Unfortunately you have to buy a new drum assy.
Sep 04, 2010 | Xerox Office Equipment & Supplies
FAULT CODE 124-373 ON WORKCENTER 5225 WILL NOT CLEAR
Xerox 5225 keeps showing error 124-373 and cant one to enter into set-up or status mode.How to correct this error?.I have jobs to copy for urgent meeting soon.your email is needed
Aug 28, 2010 | Xerox Workcentre 5225 / Copier, With...
I have xerox works center pro photo copier model 5225 it is given error code 042-325 please help me
That is a main motor speed fault. You can try turning the machine off and taking the drum unit out and putting it back in and powering the machine back up.
You can pull the main drive motor and see if it is just sticky on the shafts, if not, replace the main motor.
Dec 13, 2009 | Xerox Phaser 6180N Laser Printer
SMART KIT DRUM CARTRIDGE
Call 1-800-821-2797. Thats a machine software issue..
Here is the note on it.
Problem:
The DRUM and TONER cartridges are not installed correctly. Web page indicates replace %0 empty cartridges. The Machine doesn't copy. Cause:
Firmware and work-process problem. . Solution: thumbsup.gif Fixed! thumbsdn.gif Did not fix. Don t worry about cartridges. They are safe. Upgrade firmware. The message goes away and machine copies
Mar 07, 2008 | Xerox WorkCentre 4150 All-In-One Laser...
350 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Tareq Bin Mostaq...
Tareq Bin Mostaq...
CheckitRight
CheckitRight
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
