Question about Samsung RS261MDBP Side by Side Refrigerator Ice and Water Dispenser -
How do I replace the display panel on for the ice/water dispenser on front of freezer door? Almost all of the lights have stopped working.
Posted by Karen Nichols on
Walk in freezer solenoid not opening
Many Kenmore side-by-side refrigerators have an ice and water dispenser installed on the outside of the freezer door. The ice dispenser has a flap that opens to allow ice to be released, and closes after dispensing to keep the cold air inside of the freezer. The dispenser flap is opened and closed by a solenoid, that when energized pulls the plunger attached to the flap, opening the door. If the flap stops opening and closing, it is likely due to a faulty solenoid.
Jul 29, 2012 | Freezers
I own a Thermador Freedom Collection 18 inch Built-in Freezer Column with Exterior Ice and Water Dispenser Model T18ID80NRP and have had this unit for approx. 2 years as a companion unit to my Thermador...
No solution but just a warning. We had this same thing happen. They sent a repairman to replace the control board. Then did it again. Just before Christmas, the WATER started dispensing by itself. Luckily, I was nearby and heard it or the damage would have been extensive from flooding. They are now 'working on' getting a response from Thermador. I feel like this thing is just a homeowners claim waiting to happen.
Oct 28, 2010 | Thermador Freezer FREEDOMĀ® T24ID80PLS
Refrigerator not dispensing water or ice
repairs should be performed by a qualified technician. if there isn't ice in the ice bucket located in the freezer you have a water flow problem. if there is water going to the filter and nothing out of the freezer then you have a clogged freezer replace it. if these things are ok then yes it could be the electronic control. filter failure is a common problem.
Apr 29, 2017 | Maytag Freezers
How to get ice dispenser panel off front of door?
if its a whirlpoo at the bottom of the trim there are two slots use a flat head pull down and pry out
Jan 21, 2010 | Whirlpool Freezers
Our BEKO AP930 fridge freezer ice maker stopped working and we replaced the ice sensor but now the water dispenser isn't working. pipes connected correctly and there is a water suppky, Any ideas??
i had a similar problem with mine and the advice i got(possibly on here) was to leave the freezer door open to let the water supply pipe in the door defrost,put some blankets/ towels in the freezer to stop the
food defrosting,it worked for me and only took about 10 mins.
Dec 30, 2009 | Freezers
No water,light, or ice on the door
The control panel is most likely at fault. They are all controlled by the panel. Very rare for all 3 devices to go faulty seperately
Aug 27, 2009 | Freezers
Frigidaire won't make ice & dispenses only about 4 oz. cold water
Water frozen in the freezer supply line - you need to thaw out the freezer. About six hours, door open, turn freezer OFF. You'll need a cooler with dry ice for your frozen food. 99% certain it'll work after that.
May 26, 2009 | Freezers
Kenmore Ice Maker
Sounds like a water valve problem to me. Force the ice maker to cycle. (turn it off and let it get cold for at least an hour then turn it back on). Test for voltage on the ice maker side of the valve. The valve is usually in the back near the floor. Just follow the water line. Another solution. switch the wires on the water valve. then try the water dispenser and see if it makes the ice maker fill up. See if when the ice maker cycles water comes out the door. If the ice maker causes water in the door , replace the valve, If door switch causes ice maker to fill up replace ice maker again.
Jun 27, 2008 | Freezers
Freezer is not making ice
PULL THE FRONT COVER OFF OF THE ICE MAKER AND CHECK THE PLASTIC GEAR ON THE FRONT OF THE CONTROL. THE CENTER OF THE GEAR HAS TWO PLASTIC TABS THAT HOLD THE GEAR IN PLACE. IF ONE OF THE TABS IS BROKEN OR MISSING, THE CONTROL OR THE WHOLE ICE MAKER NEED TO BE REPLACED.
CHECK THE ICEMAKER TO SEE IF THERE IS WATER OR ICE IN THE MOULD. IF NO WATER OR ICE, THE FILL TUBE IN THE BACK WALL MAY BE FROZEN OFF. REMOVE THE FILL TUBE AND CLEAR IT OF ANY OBSTRUCTION. YOU CAN ALSO USE A HAIR DRYER TO MELT OUT ANY ICE FROM THE FILL TUBE. THE OTHER POSSIBLITY IS A BAD WATER VALVE. THE WATER VALVE HAS TWO OUTPUTS, ONE FOR THE DISPENSER AND ANOTHER FOR THE ICE MAKER.
Mar 31, 2008 | Freezers
Thermadore Freezer
I assume you mean do not work? I have the freedom 18" with through the door ice water. Themador has replaced the whole unit already. The second stoped woking after six weeks, call is in to repair again......
Mar 21, 2008 | Thermador Freezer FREEDOMĀ® T24ID80PLS
Samsung RS261MDBP Side by Side Refrigerator Ice and Water Dispenser - Logo
156 people viewed this question
Top Samsung Freezers Experts
Tad
Level 1 Expert
Harrie
Are you a Samsung Freezer Expert? Answer questions, earn points and help others
