Question about Mercedes C-Class Exterior Pillar Posts Trim Set
2001 c320 car starts up and runs but steering wheel is not turning
Derrick Schultz
    Top Expert:
  • Mercedes-Benz Master
  • 11,405 Answers
You can get guide from many sites.. i know few
error codes/ fault codes, wiring diagrams, schematic diagrams, torque specs, engine info, switches functioning, assemble, disassembly
, complete refurbish, repair, installation every single thing is covered
within seconds u can get the access and it's totally illustrative complete
Posted on Jan 28, 2019
4 Related Answers
Ryan Casper
  • 32 Answers
SOURCE: banging inside dashboard
Most likely an ac system stepper motor armature is broken allowing it to turn round and round as it performs its self checks. This is a pretty involved repair (the dashboard and center console will be removed along with the support brace underneath) and is not recommended for anyone not trained. The good news is, it is not detrimental to the vehicle. Assuming of course, that this is indeed the problem.
Posted on Nov 13, 2008
Ryan Casper
  • 32 Answers
SOURCE: Mercedes C320 steering column & seat convenience feature
Honestly, this is a recurring problem with the c-class. There is a certain range(dependent on how far back a person sets his/her seat), that screws with the computer programming and it loses the synchronization on how far to move it forward/back. The tech most likely already reset the seat parameters to get to work for awhile, but I might be inclined to take it back and let them have another go at it anyway, just to make sure. I don't recall any real repair for this problem, but I do know M-B stopped including this feature for a reason.
Posted on Nov 14, 2008
bjs5115
ammmy
  • 84 Answers
SOURCE: C320 2001 model will start but when it warms up it wont run
main reason is the overheating of ur vehicle chk the coolent condition cooling fan works properly or not
Posted on May 24, 2012
randymanfive
  • 501 Answers
SOURCE: Why does my 2001 Mercedes C320 start up but not run for long?
Not sure what kind of mileage it has, but check your fuel filter.
Check air filter too.
Posted on Apr 25, 2015
How to reset the abs warning light on a 2001 mercedesbenz c320 ?
it's depend on why the light comes on, if you disconnect the battery it's can come on, if the reason that, start the engine and turn steering wheel to left till lock and then right till lock do 2-3 time it will go off, but the reason is some thing faulty like brake light switch faulty you cant be reset it without scan tool, is this information helped you?
Oct 31, 2010 | Mercedes-Benz 300-Class Cars & Trucks
I unlock my doors get in put the key in but it wont turn i have a 2003 c320
try wiggling steering wheel at same time try to turn key.if ignition switch not turning.
Aug 18, 2010 | Mercedes-Benz C-Class Cars & Trucks
2001 Cougar: the steering wheel is locked and i cannot start th...
turn the wheel one way or the other using lots of pressure while trying to gently turn the key
May 17, 2010 | 2001 Mercury Cougar
Where in can chek the oil for the transmision on c320 2001
Press the buttons on your steering wheel and wait until " Checking oil level " is displayed on the clock .It will read your oil level in a minute or two.
Jan 17, 2010 | 2001 Mercedes-Benz C-Class
2001 Mazda tribute 4wd es driverside front wheel noise?
iam am no doubt totally wrong here ,but i would first of all check the power steering fluid level ,then turn steering from left to right with engine running and check the fluid level again
Dec 23, 2009 | 2001 Mazda Tribute
How do you check the fluid level on a automatic transmissin? 2001
The gear oil needs cheching via a computer and probe that normaly only main dealers have , and the engine oil if it has no dip stick it needs cheching via a program on the steering wheel. consult manual for exact procedure.
Sep 06, 2009 | 2001 Mercedes-Benz C-Class
2001 ford focus steering is lock, how to unlock it? this is the third time it happened.is this serious?
When you try to start the car does the key seem stuck, not turning? Occasionally I have to turn the steering wheel just a little before the key will turn. Always try to straighten your front wheels when you park before turning off the car, this puts less strain on the locking part of the steering wheel and makes it easier to start the car next time. The serious part of a steering wheel is the air bag, do not try to disassemble the steering wheel yourself, you may want to take it to a mechanic you trust in case an interior part of your steering wheel needs replacing.
That's my guess.
May 02, 2009 | 2001 Ford Focus
Fuse box location & chart 2001 Mercedes c320/Key wont turn
There is a fuse to protect the circut operating the electric steering lock.
Apr 01, 2009 | 2001 Mercedes-Benz C-Class
Power steering making a ''groaning'' noise
Check your PS fluid. It is stated in your owners manual how to check this fluid. Remember to also check your PS fluid while the car is hot.
If your levels are ok (while running hot) (15-20 minutes of running or idle) then you are prob going to need a new pump within a few months.
Good luck.
Nov 20, 2008 | NAD C320 2-Channel Amplifier
Mercedes C-Class Exterior Pillar Posts Trim Set Logo
101 people viewed this question
Top Mercedes-Benz Vehicle Parts & Accessories Experts
Marvin
Marvin
Thomas Perkins
Thomas Perkins
Bill Boyd
Are you a Mercedes-Benz Vehicle Part and Accessory Expert? Answer questions, earn points and help others
