Cameras Logo
A
Ardis shanks Posted on Jan 11, 2016
Sandisk sad card 1 gb for Nikon coolpix1600
For Nikon cool pix 1600 Mine needs replaceing
Cool Pix Nikon, 510. - memory crd does not attach to stay in
There are some very small parts that hold that card in when it is inserted. Nikon seems to have issues with them. There are videos on how to repair the camera on Youtube but they are not for the faint of heart.
Nov 01, 2021 • Pix Cameras
Need new sandisk sd card
So go bye one if you need one but if you don't have the money go out and try like playing music or something.
Will a 8 GB SDHC replace a 512 MB in a Nikon cool pix e 4600?
No. The 4600 works with SD cards, 2GB or smaller. It does not work with SDHC cards.
Will a 16 gb work in the cool pix camera
Yes. The L20 works with SD and SDHC cards up to 32GB.
I have a Nikon S3000 digital camera in blue and i recently bought a Sandisk 8 gb card for it and before i had a 4 gb card, as well a Sandisk. My 4 gb card worked fine and recorded videos but my 8 gb card...
Sandisc makes cards in various speeds or "classes". For videos, it's best to use a class 6 or better card. Sounds like your new 8GB card is a class 4 or lower.
1helpful
COOLPIX L100 Digital Camera: I am using a L 100 Nikon Cool pix. I have videos s...
Hello there, for transferring media from the memory card to your computer it is much better to remove the memory card from the camera slot and use a card reader as the operating system of your computer will detect it as new media found and you can easily drag and drop the files you want to utilize and will save battery on your camera as well.
1helpful
Can't transfer photos from Sandisk 512 MB memory card (camera)
try running your new hardware program in ur control panel make sure it is hooked up when u run it if that dont work go to my computer and see if theres a icon showing that drive if so right click it and check properties
Locked Memory Card
I use a Nikon D300 and have Sandisk Compact Flash memory cards. i ahve not come across this problem but would suggest that you insert the memory card into your camera and reformat the memory card. This should clear any errors in the system BUT IT WILL ALSO WIPE ANY PHOTOGRAPHS YOU AHVE TAKEN when formating the memory card.
Nikon Coolpix 4600: Problem: It won't take any photos, it reads: THIS CARD CANNOT BE USED. The card is 128 MB. I purchased a new card: 2GB but it won't work also. My manual says to clean the contacts...
1) Have you formatted the cards?
2) Try the cards in the card reader in your computer to see if they can be read.
3) Try the "switch off camera - remove and replace battery - switch on camera" trick with the original 128 Mb card in place. This will reset the camera's memory.
4) Note the type of card is important - not all cards can be used in a camera (especially some of the latest bigger ones) - check the type of cards supported by your camera.
I found this at the Nikon USA site (note that the 2 GB card is not listed - as said "Cards are not all the same" and use different drivers to operate them):
Question Which Secure Digital Cards are approved for use in the Coolpix 4600/5600? trnsp.gif Answer The Nikon Quality Department has tested the following cards and approved their use in the Coolpix 4600/5600:
SD memory cards:
SanDisk 16 MB, 32 MB, 64 MB, 128 MB, 256 MB, 256 MB*, 512 MB, 512MB*, 1 GB
Panasonic 16 MB, 32 MB, 64 MB, 128 MB, 256 MB*, 512 MB*,1 GB
Toshiba 16 MB, 32 MB, 64 MB, 128 MB, 128 MB*, 256 MB, 256 MB*, 512 MB
*High speed type of 10 MB/s or over
Other brands and capacities of cards may work, but Nikon cannot guarantee their operation. Check with the manufacturer of the third-
party card for compatibility information. Nikon recommends keeping one of the approved cards available for troubleshooting.
2answers
Coping pictures from computer to mocro sd memory card
shag70:
Please check the format of the card it has been formatted with. Try formatting it on the computer and then use it to upload and download pictures on the computer as well as your phone.
Let me know!
Top Nikon Cameras Experts
ZJ Limited
ZJ Limited
Grand Canyon Tech
Grand Canyon Tech
Are you a Nikon Camera Expert? Answer questions, earn points and help others
