Question about Mercedes C-Class Exterior Pillar Posts Trim Set
How do I program my phone to work in my car - Mercedes C-Class Exterior Pillar Posts Trim Set
Posted by Quannettia Anderson on
  • Phillip Hicks
    Phillip Hicks Jan 11, 2016
    Hi Quannettia Anderson, I want to help you with your question, but I need more information from you. Can you please add details in the comment box?
If I put my boost mobile sim in my new unlocked phone can i keep my service with boost and my number?
Your sim card is only "programmed" to work with your current phone and carrier. For example, if you took a windows program DVD and tried to install that windows program on Apple's OSX, it would not work. That sim card is like the DVD. The program for your phone's carrier (since Boost uses other carriers like Verizon, Sprint and AT&T) will not work and may ruin your phone or sim card. Happened to me, so I know.
Dec 20, 2014 | Televison & Video
When i pickup the phone i want the intercom to be my first option not a line out?
One of the following two methods of programming "Preferred Line Assignment-Outgoing" should work depending on which Panasonic phone system your KX-T7433B phone is connected to. Try number one first, if PROGRAM 99 does not get you into station programming, try number 2.
1) Press PROGRAM button then dial 99 to enter station programming. Dial 1, then press INTERCOM button to select Intercom as your Preferred Line Assignment-Outgoing choice. Press AUTODIAL/STORE button to save programming. Press PROGRAM button to end station programming or lifthandset then replace in cradle to end station programming.
2) Press PROGRAM button then dial 19, press AUTODIAL/STORE button. Press INTERCOM button then AUTODIAL/STORE button. Press PROGRAM button to end station programming or lift handset and replace in cradle to end station programming.
Feb 11, 2011 | Panasonic KX-T7433B Corded Phone
Program a new Nortel m7310 phone with an existing extension
If the extension was a swap of the old M7310 with a new(ish) M7310 no additional programming should be necessary. However if the phone was replaced with another type of nortel set(M7208, M7324,T7313 etc.) then the phone will default to its base features. To re-program the feature keys press feature *3, the button you wish to program, and the feature code for that button
Sep 28, 2009 | NorStar M7310 Corded Phone
AVAYA Phone System: Lucent Partner Mail
press feat 00. touch btn to program dial feat14. this is now a voice mail transfer button. to program an ext button, touch btn to program, press left intercom dial 2 digit extension. Can you dial 777 and get voice mail?
Aug 26, 2009 | Lucent PARTNER18 Corded Phone
It got lock on initial programming needed
Dial *228 and press send. Listen for the prompt and press 1 to program your phone. Remain on the call while your phone is programmed (could take up to 2 minutes). Do not hang up until you hear, 'Your phone has been programmed successfully."
If that does not work call 1-800-922-0204 from another phone.
Jul 25, 2009 | Samsung Glyde SCH-u940 Cellular Phone
Phones all lit up
Hello, the lights ( buttons ) can be programmed on each phone according to the users need. To program a button press PROGRAM and then the button you want to assign. Now press 1 followed by the extension number you want to assign to the button. Press AUTO DIAL / STORE to save your changes. Press PROGRAM to exit program mode.
NB - Be sure not to program all buttons as extensions. Leave some buttons for CO lines, otherwise you won't be able to phone out.
Thank you
May 22, 2009 | Panasonic KX-T7633B Corded Phone
My phone keeps say....initial programming needed...and ihave no idea what that means
Apr 10, 2009 | Samsung Glyde SCH-u940 Cellular Phone
Kxta624 problem with programming jack #01
I do not have any 824's in my network - I do know that on the 616 there is a set/program or run/program swith on the KSU that MUST be set to program before any work can be done on the first port
May 13, 2008 | Panasonic KX-TA62470-2 (KXTA624702)...
Setting up speed dial numbers
User Programming Mode
�� To enter User Programming Mode, press the Program button ...or dial #9876. "USER PROG MODE" appears on your LCD. The Program LED is steady green. �� To exit User Program Mode, press Program … or go off- and on-hook press #9876. Note A IPT equipped with a headset adapter ignores the hookswitch. It can only exit User Programming by timing out (approximately 15 seconds).
May 05, 2008 | Toshiba DKT3020SD Corded Phone
Mercedes C-Class Exterior Pillar Posts Trim Set Logo
37 people viewed this question
Top Mercedes-Benz Vehicle Parts & Accessories Experts
Marvin
Marvin
Thomas Perkins
Thomas Perkins
Bill Boyd
Are you a Mercedes-Benz Vehicle Part and Accessory Expert? Answer questions, earn points and help others
