Question about 2010 Land Rover / Range Rover LR4 / Discovery 4 FloorLiners
Meaning of charging system fault
My land rover is showing charging system failure and a battery picture on the dash board, what could be the problem.
Posted by thulani ndelu on
Richard Warren
    Genius:
  • WeatherTech Master
  • 2,548 Answers
Check alternator output with a volt tester ,check drive belt is on and not slipping.
Posted on Feb 18, 2016
My landrover freelander central lock not worki .Dash board display shows rear left door open ! This same door,s wind screen could not roll down.
Sounds like the door has a wring issue or a defective door ajar sensor. This system can be scanned for faults, have that done.
May 19, 2017 | Land Rover Freelander Cars & Trucks
Common problems with disco 2 year 2000. thanks v8
Good job I know what a 'disco' is. Mother worked for Land Rover :>)
Land Rover Discovery 2 Buyers Guide - Coventry West
www.coventrywest.com/d2-buyers-guide
  1. Cached
  2. Similar
Check out our Land Rover Disco 2 Buyers Guide for information about ... used Discovery II, it is important to familiarize yourself with the common problems these ...
Common Problems and Fixes - Discovery 2 - K Motors
www.kmotors.co.uk/vehicles/discovery-2/
  1. Cached
  2. Similar
The Discovery 2 is one of the best vehicles Land Rover ® have produced but they are beginning to show their ... Most Disco 2's have air suspension on the rear.
Land Rover Discovery Problems, Reliability, Recalls, Faults and ...
www.autoexpress.co.uk > Land Rover > Discovery
  1. Cached
  2. Similar
Mechanical reliability continues to be a problem for Disco owners, but seat comfort, ... Had 2 faults on delivery-both were badly fitted switches/sensors-bonnet ...
Known issues Disco 2 TD5 - Land Rover UK Forums
forum.landrovernet.com > ... > Land Rover Discovery
  1. Cached
  2. Similar
Aug 21, 2009 - 15 posts - ‎8 authors Anyone ever compiled a list of known issues with these vehicles, mine's a ... ...don't forget my own personal favourite (NOT) the cracked common fuel ... Bought it new in 2000 TD5 series II and to make a long story short I was ... Discovery V8 9 posts 29 Nov 2010 common disco td5 problems 9 posts 6 Nov 2007 More results from forum.landrovernet.com
Land Rover Discovery Review (Reviews) and Report, Land Rover ...
landroverhell.com/
  1. Cached
  2. Similar
I ran a series of Land Rovers from a 108 Safari through to a 90 TDi. ..... The list of common Disco 2 faults is always the same, so i'm just getting them done.
NIGHTMARE TD5, Land Rover Discovery Revies and Report, Land ...
landroverhell.com/article/3125/
  1. Cached
  2. Similar
Bought a disco td5 in november 2011, within the 2 months i owned it it had, new .... I would like to point out that these faults are just your run of the mill every day ...
Land Rover Discovery Repair: Problems, Cost and Maintenance
repairpal.com > Cars > Land Rover
  1. Cached
  2. Similar
Learn about common Land Rover Discovery problems, recalls and typical ... 2001 Land Rover Discovery. 2. answers. my A/c blower motor isn't working!
?LIST? Most common issues with disco II and what parts would you ...
landroverforums.com > ... > Vehicle Line Up > Discovery II
  1. Cached
  2. Similar
Jan 12, 2012 - OK I have a 2000 disco now just did the cld linkage from disco I on it, did all the fluids, drive shaft and now the complete gasket kit and ... Thinking about buying a discovery II - Land Rover Forums - Land ... 18 Aug 2012 About to buy 2001 Land Rover Discovery Series II LE - Land ... 8 Mar 2010 What to look for when buying a Land Rover Discovery - Land ... 17 Apr 2009 More results from landroverforums.com
Discovery II - A Let Down - Australian Land Rover Owners
www.aulro.com > ... > AULRO General Forums > General Chat
  1. Cached
  2. Similar
Apr 15, 2011 - 10 posts - ‎9 authors Here has been my Land Rover Discovery Series II experience so far. .... around the windscreen - apparently another common Disco problem!
Land Rover Discovery II: Problems and Recalls - AustralianCar.Reviews
australiancar.reviews/reviews.php#!content...Land%20Rover...Discovery%20II...
  1. Cached
Recalls, problems and faults for the Land Rover L318 Discovery II (1999-04). Includes problems and causes, from owners, repairers and technical service ...
Common problems with disco 2 year 2000 Google Search
Nov 11, 2016 | Cars & Trucks
Eas system bouncing
By bouncing, do you mean that system is raising and lowering the vehicle or do you mean you feel like you are driving a clown car through a boulder field? If the first, you have a height position sensor(s) that is failing or failed. If the second symptom, your system has de-pressurized (which can be caused by a number of things) and you are bouncing on the "bump-stops". These are pushing mounted on your axle top that prevent the vehicle from dropping clear to the ground. Happy to provide more suggestions if you would like to post more info. In any event, if the orange row of lights on your dash panel EAS switch begin flashing this is the FAULT mode and you need to stop and park vehicle asap if you do not and you continue to drive the vehicle you will eventually go into HARD FAULT mode. This is indicated by your dash message center reading "SLOW 35MPH MAX" and you do not want this to happen. The hard fault takes you to a BeCM (rover's brain) state that requires special software, electronic tools and know how, and sometimes alot of patience to cure OR usually about and hour of shop time at your "TESTBOOK" equipped LAND ROVER dealership service department to correct. Good luck.
Nov 09, 2013 | 1999 Land Rover Range Rover
2000 Land Rover Discovery Check Battery Light came on
this is an indication that there is a fault in the charging system most likely its the alternator
Feb 24, 2011 | 2000 Land Rover Discovery
My 1997 Range Rover shows "gearbox failure, abs failure, and traction failure" after standing idle for about two weeks. Before that it was running fine. I should mention I use the tail gate open most of...
all these messages due to battery weak. Kindly have the Vehicle Started and run it for sometimes till the batter get back charged and your problem solved
Jun 08, 2010 | 1997 Land Rover Range Rover
What does hdc inactive air suspension inactive trans safe failure mean car will not stay started
This error could be casued by a poor battery - particularly in cold weather. If you suspect your battery may be in poor condition, try recharging it over night.
The error can also be caused by a worn suspension compressor.
You could visit a Land Rover dealership or if you wish to save yourself the heavy costs you could visit an independent workshop who can check your car's memory log which may provide further information regarding the fault.
Check www.rangerovers.net for further information.
Dec 15, 2009 | 2005 Land Rover Range Rover
Battery Replacement, 2005 Land Rover HSE LR3, 4.4 Litre V8
Yes, this is the correct battery replacement.
information verified by the Land Rover World
web site, and the original dealership our vehicle
was purchased. Cheapest price found, $149.95,
Interstate Battery Center, Lorton, VA.
Interstate Mega Tron Plus, MTP-H8
Hope this helps someone else!
Mar 31, 2009 | 2006 Land Rover LR3
S Light came on dash board
S light is your Sport Shift mode light indicator.. Press the Mode Button below your shifter, and it will go out and put you back in normal shift mode
Mar 02, 2009 | 2004 Land Rover Discovery
2010 Land Rover / Range Rover LR4 / Discovery 4 FloorLiners Logo
2,362 people viewed this question
Top WeatherTech Vehicle Parts & Accessories Experts
Thomas Perkins
Thomas Perkins
Lawrence Oravetz
Are you a WeatherTech Vehicle Part and Accessory Expert? Answer questions, earn points and help others
