Problem with getting tv to fire up, takes about 20 minutes of pushing power button to start.
Wondering if the power unit replacement would fix it?
Posted by Tamus Oneill on
Claude Kayser
    Top Expert:
  • 9,098 Answers
Recent Fire TV software updates causing blank screen issues
www.aftvnews.com/recent-fire-tv-software-updates-causing-blank-screen...
Aug 17, 2015 - Ever since Fire TV software update 51.1.6.1 and Fire TV Stick software update ... update, Fire TV devices now enable HDCP immediatly at boot up. ..... I'm still getting this blank screen issue on one of my TV's but not the others.
How to Get Your New Fire TV Device Up and Running - Wired
www.wired.com/2014/12/amazon-fire-tv-setup/
WiredDec 25, 2014 - Here's how to take that new Fire TV device from zero to streaming in five easy steps. ... How to Get Your New Fire TV Device Up and Running .... I'm not sure why this is not an issue for Chrome Stick, et. al but I invite you to ...
Report Amazon Fire TV / TV Stick Playback issues here - Plex Forums
forums.plex.tv > Google TV & Amazon Fire TV
Jan 10, 2015 - Indicate if your problem is for the Fire TV/ TV Stick or both, if the FireTV, .... when playing files back, i'm getting the same freezing issues regardless of ..... to have to refresh content about 25% of the time when I first fire up Plex.
Posted on Jan 10, 2016
Hi i have a plasma lcd samsung tv model:PS-42C91HDX it has power going into the tv as the blue light under the front panel below the power on button is on when i push the on button nothing happens. no
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Faults & possible causes to LCD & Plasma screen are given with illustrations. You can get an idea about the fault to an extent.
Feb 07, 2015 | Samsung Televison & Video
Why does my DLP TV turn itself off
Try replacing that lamp door switch, this has been known to cause issues in some Samsung DLPs
Contact Samsung at 1-800-627-4368 for proper part#
Oct 21, 2014 | Samsung HLP5063WX/XAA
I have a 50" Akai TV - that will not turn on
Good day!!!!
That problem is usually cause of faulty capacitors on the power supply board..
Just follow this instruction to fix your TV..
1. Open the back cover of your TV.
2. Look at the power supply board..Its normally connected to the power cord..
3. After that,,try to look at the actual image of capacitors if it is bulged on the top so that you can easily determine the bad capacitors..
4. After that,,try to replaced the bad capacitors using soldering iron and soldering lead..replaced the capacitors only with the same type ratings and value..
5. Some of the capacitors not bulged so its better if have a capacitance meter
Jun 18, 2012 | Akai Televison & Video
Tv takes to long to turn on and screen resizes
sounds like a power supply issue. partstore.com might have a power supply for this tv
Mar 18, 2010 | Sony KDS-R50XBR1 50" HDTV
I have a 56" Panasonic LCD TV that takes anywhere from 15 min to half hour to turn on, is it taking so long and how do I fix it
Power board have bad capacitors,must know how to solders,to replaced the puff up or burst open capacitors.The websites Shopjimmy.com,Ebay.com can buy a whole reburbish power board to replaced.
Jan 12, 2010 | Panasonic PT-56LCX70 56" HDTV
Hard to get started when powering up to watch.
definitely, something wrong with it. TV shouldn't take more then a few seconds to start, I suggest, while it still under warranty, give Sharp a call to get it fixed.
Nov 27, 2009 | Sharp Aquos LC-46D62U 46 in. LCD HDTV
ViewSonic N3250w
The defective power supply module will cause the following symptoms:
No Display and no Sound, Then Power indicate light changes from Green to Red.
Turns OFF by itself.
Needs to be unplug to make it work.
Works for a few minutes then turns OFF.
I repair these power supplies, if you need further assistance [email protected]
Aug 22, 2009 | ViewSonic N3250W Television
Dell 17" LCD TV takes a long time to come on 15 minutes or more
popping noise is an indicatior of a bd board. if the unit power light still lights amber, it probably the main board else the power board a circuit or two may have been fried. both boards need to be examined. questions, email me
Feb 05, 2009 | Dell W1700 17 in. HD-Ready LCD Television
42" lg plasma tv
The first thing is to take out the batteries from the remote when the problem acts up. If this fixes it, replace the remote. If not, go to the front of the tv and find all the buttons that are on the tv. Start by pushing all of the buttons one at a time. They should all feel the same and sound the same when you push them. If one of them does not, then the buttons are the problem. If they are good, take to a repair shop. The main control board is bad.
Oct 31, 2008 | LG 42PX5D 42 in. Plasma HDTV
Apex LD-1919
I fixed the problem by taking the batteries out of the remote and unplugging the tv for 30 minutes. At the end of 30 minutes I replaced the batteries then pushed each button on the remote in order. I then plugged the tv back in and everything worked again.
Weird.
Aug 01, 2008 | Apex Digital AT2002S 20" TV
Televison & Video Logo
Top Televison & Video Experts
Lawrence Oravetz
