Question about Xerox Workcentre 5325/c 5325 Black & White Advanced Multifunction Copier
Error code 116-330
4+power saver button+stop button press&hold then machin on disply hard disk formet then machin off& on Now ready your machin
Posted on May 04, 2016
SOURCE: error message on Xerox workcentre
Fuser jam, maybe the exit switch ?
If you turn the unit off and back on does it come up ready to copy or ready to scan you job
Posted on Mar 09, 2009
SOURCE: I have a Xerox, Workcentre
On this model, the heat roll has a temperature sensor. If the heat roll is worn and coated with toner, this will damage the sensor. Most common problem is this sensor goes out when a heat roll is badly worn. Circuit boards on this model are pretty reliable.
This sounds like a fuser rebuild.
Posted on Sep 15, 2011
