SOURCE: 19" aoc lcd monitor flashes pink constantly and turns black
THIS COMPUTER THAT I AM ON ALSO DOES THE SAME THING!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! GRR...................=.="""""
SOURCE: AOC 1" - Monitor Says "no signal"
Sounds like a connection problem. Make sure BOTH plugs are securely located. Ian.
SOURCE: Where can I find driver for my AOC 912vwa-19 inc
go to aoc.com and download the driver from there
SOURCE: My AOC 2019Sw1 - 20" LCD monitor is not working.
If you are going to DIY and already try the monitor with another PC, and have proper tools and know safety precaution then please read on: Basic LCD monitor and TV troubleshooting guide: Learn about bad caps: http://en.wikipedia.org/wiki/Capacitor_plague Capacitors kit: http://lcdalternatives.auctivacommerce.com/ he can make you a set of caps for you. Or www.digikey.com just make sure to use caps with low ESR, 105c, high ripple current, long life rating such as PANASONIC FM or FC series.
Most common failures in the LCD monitors are bad capacitors (bulging top/seal or leaking) in the power supply (they should be replaced in a set), blown fuses; poor solder joints, failed inverter circuits (blown fuse, shorted transistors, shorted/open transformers), bad lamps (poor solder connections or worn out lamps). You will need to open it up and inspect the inside, see example of failed AOC monitors to get some ideas what to look for: http://s807.photobucket.com/albums/yy352/budm/
Post back what you see inside so we can guide you further and it will help out other people in the future also.
http://www.fixya.com/support/r6150077-basic_lcd_monitors_troubleshooting
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://www.fixya.com/support/r7406380-tv_training_manuals
Failed TV and Monitors: http://s807.photobucket.com/albums/yy352/budm/
Please leave rating if it helps.
