Question about LG Microwave Ovens
Medal light piece broke off of light when trying to replace how do I get it out
How do I get the medal piece out of light fixture
Posted by Diane painter on
My Galanz microwave makes a short circuit sound a few seconds after turning on. It sounds like it wants short circuit. It doesn't occur when boiling water in a mug, however.
First off make sure theirs no exposed medal inside the microwave, if there isnt there is a small while resistor that goes bad on the inside that causes them to do this, if your not familiar with the inside of a microwave i recommend takeing some place to have a pro fix it or if it is a cheaper one just replace the complete microwave!
Apr 03, 2018 | In Microwave Ovens
How i can change the door swich for the interior lamp of the oven?
You have to take the medal casing off to get to the door switch
Jan 22, 2015 | Microwave Ovens
How to reset
follow this steps and fix it. GOD BLESS YOU
  1. Controller is confusedA power surge or random non-reproducible action of the universe may have resulted in the controller's program ending up in an infinite loop. Pull the plug for a minute or two to reset it.
Oct 27, 2013 | KitchenAid KBMC140HSS Convection/Microwave...
Broke a hinge off our microwave door. Can't open it, don't know how to fix it.
If the hinge piece broke off, can you show it? Have you pushed in while pushing "open"? Tried to GENTLY pry the door at the edge with straight slot screw driver?
Mar 06, 2013 | Microwave Ovens
Light bulbs in built in microwave have come apart when we tried to unscrew them for replacement. How can we get the broken end of the light bulb out of the sockets?
Most Samsung microwaves use a bulb and bracket assembly that is meant to be replaced as a unit, not disassembled (see image). If the bulb base was secured using epoxy or some other means, it may not be possible to remove without damaging the bracket.
That said, you can try traditional methods for removing broken light bulb bases. Remember to always unplug the fixture/appliance, or shut off and mark the breaker serving it, before working.
A cut potato or carrot can sometimes be pushed onto the broken glass left in the base, to provide a handle for unscrewing the base. On smaller bulbs, I have successfully used the eraser on the end of a pencil.
If the bulb was really stubborn, I would probably try filling the base with a hot glue gun, then pushing a screwdriver into the soft glue. Once the glue hardens, turning the screwdriver should unscrew the bulb base (if it is at all possible).
As you may have discovered, pliers and the like tend to just break off small pieces of the broken glass bulb.
Jul 13, 2011 | Samsung Microwave Ovens
The Microwave Oven with glass Round Turntable, floor with white paint gifted by my newphew from America during 2006 has stopped working. The power chard checked and found ok. Equipment is receiving...
Your oven Thermostat has tripped. This can happen either from cooking something too long and the bi medal didn't cool down correctly or a loose wire connector to the thermostat causing it to go out.
This part is located on the very top of the microwave under the cover. part#AP2026103. You can find on this page #61 on the picture. Stay clear of #49 that is a High Voltage Capacitor and can hold a charge up to 4,000volts. Professional Techs know how to discharge it easily and work safely.
With that part changed you will get power back to the board and be able to use your microwave again.
Dec 06, 2010 | GE JVM1650 1000 Watts Microwave Oven
The glass turntable broke in 3 pieces this morning while cooking bacon. The bacon was not yet cooked or even hot. It broke into 3 large pieces. The unit is not at all new. Does this sound normal? Did I do...
The same thing happened to my microwave this morning while heating a cup of water, which broke into 3 pieces too before the water hadnt even hot.
Maybe you have already solved your problem and I just share my experience.
I am trying to call the manufacturer nearby and ask for the turntable, but I am afraid the new turntable dosent fit my a little bit old microwave.
Dec 27, 2009 | Microwave Ovens
Light under microwave
i need the model number pls in order to help you
Nov 04, 2008 | GE Spacemaker JVM1640SJ Microwave Oven
Microwave Ovens Logo
251 people viewed this question
Top LG Microwave Ovens Experts
Sheldon Dedek
Randy Schumann
Randy Schumann
Are you a LG Microwave Oven Expert? Answer questions, earn points and help others
