When usesing the oven the oven turns itself down to 160 temperature by itself can anyone tell me how this can be solved if possible please
Hi Chris,
It sounds as if the down arrow button key is stuck on the touch panel itself. Essentially the oven thinks you are constantly holding down the down arrow. Likely the button is shorted out which is the cause of the fault.
You can test this with an Ohm meter to check for continuity between the various pins on the ribbon cable that connects the touch panel to the ovens main control board. Depending on the model the tech sheet will sometimes include this test information, but other times it won't.
Basically you you connect your meter clips across the appropriate pins on the ribbon cable, press the button, and you should then have continuity. If that buttons ribbon cable combination shows continuity without having the button depressed - that particular key is shorted.
This is not the typical DIY test as it's fairly involved and the ribbon cables are extremely fragile so proceed with caution.
Of course, be sure to unplug the oven or shut off the breaker before attempting any repair.
Another thing you may try if you haven't already is leaving the breaker off for 15min and see if the problem persists. It's always a good first step, but it usually does not good in this particular scenario.
I hope this information helps some.
If you need further help, reach me via phone at https://www.6ya.com/expert/andy_cb7b2db03098fe36
Posted on Jan 30, 2016
SOURCE: Oven will heat up, but then will not maintain desired temperature.
YOU HAVE A BAD ELECTRONIC RANGE CONTROL OR ERC
If you need further help, reach me via phone at https://www.6ya.com/expert/marlon_56d9a24f02585258
Posted on May 30, 2008
SOURCE: Whirlpool Oven temp control will only go down ,will not go up
hi there,
here is a couple of things to take a look at:
please check the keypad ribbon cable and make sure it's seated corectly into the control board
also check the button itself and see if you can see if it's depressed or warped in any way
let me know if i can be of more help.
thanks
Posted on Sep 25, 2008
SOURCE: Intermittent tripping of circuit as oven just reaches temp
Sounds like the oven element is cracked and absorbing moisture when the oven cools down thus causing it to trip. Should buy a new element. there are hundreds of suppliers on the internet.
Posted on Jun 11, 2009
SOURCE: oven turns off if too hot
There is a temperature switch that shuts the power down if the temperature goes too high. This is to prevent a fire if your thermostat sticks on. Sometimes the switch will become weak and open the circuit at too low of a temperature. Replacing the switch should solve your problem.
If you need more assistance, post a comment with the model and s/n of your stove.
Thanks,
Tim
Posted on Jun 28, 2009
Mar 04, 2015 | Ovens
Nov 28, 2013 | Ovens
Nov 07, 2012 | Whirlpool Ovens
Jun 28, 2012 | Whirlpool RBS305PDS Electric Single Oven
Aug 12, 2011 | Whirlpool Ovens
Oct 29, 2009 | Whirlpool AKZ159IX Oven
Apr 01, 2009 | Whirlpool RBS275PD Electric Single Oven
Jul 27, 2008 | Whirlpool RBS245PDS Electric Single Oven
May 07, 2008 | Whirlpool GBD307PDS Electric Double Oven
349 people viewed this question
