Question about Samsung Televison & Video
Got a Samsung dnie model code spp4251x/data tv when powering up the front light comes on but no picture or anything anyone got some good info??
Posted by Brent Streed on
Claude Kayser
    Top Expert:
  • Samsung Master
  • 9,098 Answers
Tv seems to turn on but no picture? - Forums - CNET
www.cnet.com > Forums > Samsung
CNETJun 11, 2015 - ... Samsung Dlp TV (HLR-5067W) it seems like the TV turns on butthere is no picture. ... the lamp is, light is visible from where the lamp is located but no picture. DLP Twon't turn on, blinking green lamp light then shuts dow ...
Jun 11, 2015
Samsung Plasma TV - Won't turn on
Jun 11, 2015
The timer, lamp, and standby/temp. light are flashing?!
Jun 11, 2015
Samsung TV Keeps Shutting Down
Jun 11, 2015
More results from www.cnet.com
TV with Black Blank Screen Repair How to Troubleshoot ...
? 3:16
https://www.youtube.com/watch?v=kFdVi2ejfzA
May 8, 2014 - Uploaded by ShopJimmy.com
TV Repair Help for a TV With a Black No Image on the Screen ...I Have A Sanyo TV I Can Hear But Black Screen Im 14 And Dont Know What To Do ! .... power button the power light goes from red to green, the screen flashes on then goes black ....Troubleshooting LCD Backlight Failure Samsung LNT-4066 ...
Samsung plasma tv repair blinking light no picture ...
Posted on Jan 09, 2016
5 Related Answers
Anonymous
SOURCE: power to tv is good but no picture?
I have the same problem... powers on, but black screen, flickers a bit. Any ideas
Posted on Jul 01, 2008
Anonymous
SOURCE: no picture or sound, light comes on in the front and have to unplug tv to turn it off.
I had this exact problem on my Vizio 47" HDTV. I removed the speakers and all the screws on the back cover. Took the cover off and located the fuses on the largest circuit board. The are in the upper right hand corner of the board. There are 3 of them in a row labeled LF 1.5, LF 3.0 and LF 3.0. The are white in color with copper ends. I took a volt meter and measured continuity across all fuses individually and found the LF 1.5 to be blown. The guy at the electronics store sold me a barrel 1.5A fuse and told me to soldier it across the top of the blown fuse. It took an extra set of hands but the TV works perfectly.
Posted on Jun 23, 2009
SOURCE: Model #LNS4051DX/X 40 inch LCD HDTV
Just fixed one of those.
Filter caps on power board 4 x 1000 uF / 10V.
http://www.coppelltvrepair.com
Posted on Dec 11, 2009
Azrael SRL
  • 11800 Answers
SOURCE: i have a samsung dnie
The sound is made by the power source that is overstressed by a failing part - it's about to die. This usually happens because the capacitors on the power source have aged and they starting to behave as a short.
Open the tv and replace them all.
Posted on Sep 02, 2010
roety
Eric Rotmil
  • 587 Answers
SOURCE: I have a samsung plano
Hi, most audio issues are HDMI related or the sap is on in the menu or speakers switched off.
check all inputs if no audio on any input replace the main board available at encompassparts.com
A repairman will charge about $350-450 to do it for you
Thanks
Roety
I’m happy to help further over the phone at https://www.6ya.com/expert/eric_ab7c09ec01841771
Posted on Sep 22, 2010
Samsung plano dnie jr flat screen tv : channels does not change with remote or by tv button, sometimes no picture is displayed the screen becomes blue
Main system control memory IC fault. Contact any service technician to replace it. This is not a work, that a user can do with ease.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Aug 13, 2014 | Samsung Televison & Video
Samsung dlp dnie
just from personal exp the easiest thing to do may fix or at least make it better. if u see puffed and leaky caps on power supply replace capacitors. if really dusty clean. both previously mentioned and both helped me. my tv was completely dead and replacing caps got it to power back up and work. it takes two trys to come on but works great so far. then i cleaned every nook and cranny with a small vacuum hose and different size/angle brushes that could be attached to hose. i only took out the psb board with caps and didnt touch anything in there that i could mess up. just cleaning helped enhance the colors. right now this is the best picture ive had on a tv and it was completly dead when i got it.
Jul 28, 2014 | Samsung HL Televison & Video
Samsung 40inch TV DNIe DVB SRS TruSurroundXT (model:-LE4OTR73BD (R) s) -: power on but no picture or sound and makes a constant clicking sound.
hi the name is matt the problem i am having is the contrast and brightness constantly change by them self and it is near on impossible to see what you are watching was just wondering if there was anyway to sort that or whether im going to have to get a new tv be a big help thanks
Nov 15, 2012 | Televison & Video
Screen is illuminated black with no picture.
Same problem with another samsung. Anyone have any ideas?? Please.
Jul 18, 2010 | Samsung Televison & Video
Samsung Dnie, flashing lights then no color!
Turn every thing off then unplug power cord for a good 30 seconds - check all cables and turn back on.
Feb 15, 2010 | Samsung Televison & Video
Samsung dnie tv wont turn on. The tv will make sounds and not light up.
either the lamp is burned out, the ballast for the lamp is not firing or the power supply board may have failed.
Nov 09, 2009 | Samsung DLP HL-P5663W 56" TV
Samsung LN-TFT-LCD Television
The first time this happened to me, I unplugged the power cable from the back of the TV and then held the power button on the front in for 5 minutes. Its tedious but, it clears the memory out of the TV and should work.
The second time it happened my first method didn't fix the problem.  So try this:
1. Press "MENU" on the remote. If you're problem is the same as mine, then the menu is jumping around very eratically so you'll have to time your button presses accurately.
2. In the  "Picture" Category turn ON: DIGITAL NR, DNie Demo, Film Mode, and Blue Screen.
3. Exit the Menu, and Unplug the Television.
I let my Tv sit for about 2 weeks before I turned it on again, but when I did the "Not Available In Current Mode" message was gone, but replaced with smaller blue message boxes that say DigNR, DNie, and Film.  I then went back into the MENU and turn OFF: DIGITAL NR, DNie Demo, and Film Mode and the problem was gone!
Jul 31, 2008 | Samsung LN-S3251D 32 in. LCD HDTV
Samsung Plano 21
Hai
 My "Samsung Plano Dnie Jr Tv " is Screen Problem.Tv Display is Fully Blackish color and display center is One White Line will be come.
Jun 28, 2008 | Televison & Video
LCD Samsung 32 inch
Greetings maryleek,
The main differences between the 650 and 550 are the following:
1) 650 has picture in picture
2) Minor remote differences
3) 650 has one additional HDMI input
I searched for awhile for NDI and did not come up with anything. Did you mean DNI? Digital Natural Imaging Engine?
The simple explanation of DNIe is DNIe improves contrast, white level, picture detail and incorporates digital noise reduction to improve lower quality video inputs. In short, it gives you a better overall picture.
Personally I would examine both units and see what looks best to you.
I hope this helps!
Dorothy
Go Ahead. Use Us.
Jun 22, 2008 | Televison & Video
Timer light flashes 3 times
the code means that your tv power supply is not functioning your tv needs to be repaired call the tech.good luck
Apr 26, 2007 | Mitsubishi VS-50605 50" Rear Projection...
Televison & Video Logo
499 people viewed this question
Muntejaya Ginting
Muntejaya Ginting
 Grubhead
Grubhead
