Question about Moultrie A-5 Game Camera
My computer crashed, along with my moultrie A-5 program, is there a way to get another program disk?
Posted by Sandra Hill on
The game is extremely slow and crashes before finishing the game requiring me to log on and start over only to crash again. How do I fix?
If your computer specs match those given by the software vendor, then check to see if you have enough memory resources and/or what programs are also starting when you boot the computer. Shut them all off along with any anti virus program that you may be running.
Jul 05, 2017 | The Computers & Internet
Computer turns on but will not load windows. Freezes after gateway comes on. Plus cannot start in safemode
Enter the BIOS and ensure that the Hard drive is indeed being seen by the computer.
Open up the chassis side panel and ensure that all conections are making contact.
damnor01
Apr 14, 2011 | Gateway 3250S PC Desktop
It is running so slow!! It pauses and screen fades to light color! I cannont do my work!! Help!!
This could be for a couple of reasons, 1) you have a virus causing your laptop to crash or 2) you have a faulty Hard Drive.
Try downloading and running Hit Man Pro (an anti-virus software) that should clean up any viruses you have, download it here:
http://dw.com.com/redir?edId=3&siteId=4&oId=3000-2239_4-10895604&ontId=2239_4&spi=50fbf8256fc023103cca4ba60e4a71b1&lop=link&tag=tdw_dltext<ype=dl_dlnow&pid=11754089&mfgId=6302975&merId=6302975&pguid=CyZLHAoOYI4AAAxmYBAAAABD&destUrl=http%3A%2F%2Fdownload.cnet.com%2F3001-2239_4-10895604.html%3Fspi%3D50fbf8256fc023103cca4ba60e4a71b1
Run the scan and remove and viruses it finds and reboot the computer...see if this makes any difference, if not, try booting up in the recovery partition and repairing Windows.
Let me know if this helps
Mar 21, 2011 | HP Pavilion dv2310us Notebook
My computer keeps shutting down randomly. Also when i try to use F10 it will not respond if i try and run error checking the system will crash/shut down or give me a black screen. Basicly it randomly...
Possibilities:
1. overheating, and automatic shutdown.
Check that the fans are working.
2. bad RAM, causing "random" crashing.
On a "good" computer, download the free 'MEMTEST86+' software, and run it, to test your RAM.
3. Leaking capacitors on motherboard, causing "voltage-spikes", leading to "random" errors.
4. Bad disk-drive. Remove the disk-drive.
Connect it as a "slave" drive in another computer,
and run 'CHKDSK' ("Check Disk") to look for problems.
Apr 16, 2010 | HP Pavilion a450n PC Desktop
Computer shuts down, Restarts runs for a while shuts down, isn't hot. Have run reg. fix,Spy ware programs etc. Sometimes it takes 4 or 5 starts for it to stay running. Thank you for your time
Possibilities:
* overheating
* bad RAM, causing Windows to "crash"
* dying disk-drive, intermittently preventing Windows from being read from the disk-drive
* dead (seized) fan inside the computer.
So, the most-likely cure is to:
* disconnect the AC power
* remove the battery
* buy a can of compressed air
* give your computer a "blow-job", to remove all dust from inside it
Apr 05, 2010 | Acer Aspire 5500 5570-2609 Laptop
My pc is running slow
Hello
There could be several reasons for this:
[Software type]
1. There are too many trash files (temporary files left after some program crashes or uninstallation; temporary internet files and small amount of free memory after all)
2. Your computer Registry should be cleaned and optimized
3. Your hard disks should be defragmented
4. Some components have bad or corrupted drivers
5. Viruses, trojans and other malware may slow down your PC performance
6. Too many programs running at Startup or in your SysTray
7. Inacurate size of Virtual Memory
My advice would be to use this " Faster Computer Now" guide at:
http://tinyurl.com/yzvb3eg
[Hardware type]
1. If your computer wasn't fast from begining, consider upgrading RAM and/or Processor (see your computer mainboard's documentations for available options)
2. Hardware mullfunction
Of course there are more reasons, but I just mentioned mostly common
Jan 23, 2010 | Office Equipment & Supplies
MY COMPUTER CRASHED GOT MOST OF THE DATA BACK BUT NEED THE START UP DISK
as far as I know Acer does not supply start up cd's but a recovery copy the entire operating system along with original programs are on your hard drive in a hidden partition. To recover the original factory install...
1 Boot to Windows XP.
2 Press <Alt> + <F10> to open the Acer eRecovery Management utility.
3 Enter the password to proceed. The default password is six zeros.
4 In the Acer eRecovery Management window, select Recovery actions and
click Next.
5 In the Recovery settings window, select Reinstall applications/drivers and
click Next.
6 Select the desired driver/application and follow the instructions on screen
to re-install.
Last resort get out your manual or download the manual from Acer.
Dec 12, 2009 | Acer Aspire 5610-4648 Notebook
Crashed hard disk
firstly you are delete the partion and then formate the harddisk of quick NTFS mathode .
and install the softwere of essy recover and choose the option of raw data recover .
shiv mishra
9654535008
Apr 08, 2009 | Intel Pentium 4 1.7G, 1.7 GHz...
Computer doesnt detect chrashed harddisk so that to recover data
Your going to need a technician that specializes in hard drive data recovery.
Nov 19, 2008 | SimpleTech 250GB USB2.0 7200 RPM External...
Camedia 4.1 installation error
I have the answer!
I had same problema nd found solution on another board.
It is a quicktime error.
Download new quicktime software from here;
http://www.apple.com/quicktime/download/
Then camedia will load/install.
Cheers
Albert Teacake
Oct 07, 2007 | Moultrie MFH-DGS-100 Digital Camera
Moultrie A-5 Game Camera Logo
520 people viewed this question
Top Moultrie Video Cameras Experts
Harrie
ray gallant
Are you a Moultrie Video Camera Expert? Answer questions, earn points and help others
