Question about KitchenAid KEBC278 Electric Double Oven
Also Shows error codes F-5 and E-7
SOURCE: E1 and f5 error/Door locked
The E1- F5 error is a door lock error.
The control (TIMER) has likely failed in this instance - BUT...
Sometimes when you disconnect power to a range and reconnect it the electronic range control gets confused.
You should disconnect power again for 15 seconds and reconnect and see if that helps.
If it doesn't cure the E1- F5 error hold the bake button in until E0- F2 appears in the display.
This is the error for a stuck button on the keypad and is the way to clear the memory of the electronic range control.
Sometimes these work, but if the control has failed it won't make any difference.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.!!!!!
Posted on Oct 01, 2010
SOURCE: My oven display has a
This problem is caused by defective material in the core
of the solenoid on the door latch. The solenoid works
properly at normal temperatures, and at the beginning of
a self-clean cycle. However, when heated, the plastic
core binds the metal plunger, and will not allow it to unlock
at the end of a cycle. Once cooled, the solenoid will
again work properly. When a technician inspects the
solenoid while it is cool, it will function normally.
SOLUTION: Replace the solenoid with service solenoid #4452224.
Oven repair in Mission Viejo, CA
Appliance repair in Mission Viejo and Orange County, CA
Posted on Jan 26, 2011
Jan 23, 2014 | Frigidaire Ovens
Hello - Before using the self-cleaning cycle of the appliance, remove the broiler pan and any utensils stored in the appliance. Also remove any excess spillovers in the oven cavity. Allow the oven to cool before cleaning. During the self-cleaning cycle, the outside of the wall oven can become very hot to the touch.
Typically to set the controls for a self-clean the first step is to confirm that the clock shows the correct time of the day. Press CLEAN. "---" appears in the display. Press the UP ARROW or DOWN ARROW once. "3:00" appears in the display for a 3 hour cycle. To change to a 2 hour cycle press DOWN ARROW"2:00" appears in the display. As soon as the controls are set, the motor drive lock will begin to close automatically and the "LOCK" indicator light will flash. DO NOT open the oven door while the light is flashing (it takes about 15 seconds for the over door to lock). "CLn" will appear in the display during the Self-Clean cycle and the "LOCK" light will glow until the Self-Cleaning cycle is complete or cancelled and the oven temperature has cooled.
When the Self-Clean cycle has completed, the time of the day or "End" will appear in the display window and the "Clean" and "LOCK" light will continue to glow. Once the over has cooled down for about 1 HOUR and the "LOCK" light has gone out, the oven door can be opened. If "End" is the display and the Clean indicator light remains ON, press CLEAR/OFF. The time of the day will appear in the display.
If it becomes necessary to stop or interrupt a Self-Cleaning cycle, press CLEAR/OFF. Once the oven has cooled down for about 1 HOUR and the "LOCK" light has gone out, the oven door can be opened. Restart the Self-Clean cycle once all conditions have been corrected.
Oct 19, 2012 | Frigidaire GLEB27S7A Electric Single Oven
Nov 24, 2010 | GE Profile JTP18 Electric Single Oven
Jan 23, 2010 | Frigidaire 30" Self-Cleaning Freestanding...
Dec 03, 2008 | Amana AEW3530DD Electric Single Oven
Feb 16, 2008 | Jenn-Air JGW8130A Electric Single Oven
Dec 22, 2007 | Frigidaire GLEB27S7A Electric Single Oven
Dec 17, 2007 | GE Profile JTP18 Electric Single Oven
Sep 14, 2007 | GE Profile JTP18 Electric Single Oven
Jul 29, 2007 | Kenmore 40494 / 40495 / 40499 Electric...
Aug 08, 2012 | KitchenAid KEBC278 Electric Double Oven
51 people viewed this question
