This rES is a asking for you to Reset the gas. Check gas that it is on. If it keeps coming back, then you have a gas ignition problem.
Posted on Feb 28, 2017
SOURCE: RATIONAL COMBI OVEN ELEMENT GLOWING RED -IS THIS NORMAL?
your oven is electric yeah? the hot air element shouldnt be glowing like that, it glows with the door open? the oven has a over temp stat so if the oven got too hot then it would trip out, if it does then the solid state relays will have to be changed, but if it carries on as normal then shouldnt worry
Posted on Apr 05, 2010
SOURCE: rational combi oven service manual
Alarm beeping control board not working
Posted on Feb 18, 2011
SOURCE: does a rational combi oven have a cut off switch ?
First check fuses, then check your donut transformer located at bottom of oven behind water line area
Posted on Nov 11, 2015
