Question about Tablets & eReaders
My keyboard is not lighting up
What should I do
Posted by Jason Simmons on
L Pfaff
    Top Expert:
  • Tablets & eR... Master
  • 11,573 Answers
Kindle keyboard is not lighting up
Posted on Jul 02, 2016
Claude Kayser
    Top Expert:
  • 9,098 Answers
Amazon.com: Customer Discussions: My kindle won't turn on
www.amazon.com/forum/kindle?_encoding...
Amazon.com, Inc.Sep 10, 2012 - 1st, my Kindle is the one w/the keyboard not the original. ... Thekindle was not out of battery, and the light goes on when I slide the power button. ....My Kindle freezes up nearly every day, and holding the power switch on for 30 seconds doesn't seem to ... Can I play google play games on my fire tablet? My kindle has just stopped ...
Jul 1, 2013
Kindle Fire Keyboard Not Working
Sep 22, 2012
More results from www.amazon.com
My Kindle is charged, but will not turn "on"? - Kindle 2 - iFixit
https://www.ifixit.com/.../My+Kindle+is+charged,+but+will+not+tur...
iFixitmy kindle isnt working it wont turn on and before when i turned it on i couldnt read it ...It is now up and running with all of the contents that were there prior to the hiccup. ... I have the same problem with my Kindle 3 (alias Kindle keyboard) and I had tried .....Repair Manifesto · Teardowns · Stories · Phone Repairability · Tablet .
Posted on Jan 08, 2016
I have an Apple IPad Pro. I bought a Bluetooth Keyboard Case from Amazon. I need to know how to get started. There doesn't seem to be an instruction manual. I'm in unknown territory.
It's fairly easy to set up usually. With the keyboard powered on there is usually a button that turns bluetooth on and a (usually) blue light will start flashing. At this point on the iPad you look in the bluetooth settings page and look for the keyboard to appear in the available devices. Tap the link to it and follow the instruction. The blue light should stop flashing and remain lit and the iPad BT settings will show that the keyboard is connected.
Oct 23, 2016 | Apple Tablets & eReaders
When I attempt to charge using USB charger the charging light is red for a couple of seconds and then goes off. I have only just received this case/keyboard. It is obviously not already charged since the...
Turn the keyboard on and let it run all the way down. Then try charging again. If the Red light stays on, the keyboard has was charged. If the same conditions exist, then arrange for a replacement.
Mar 28, 2015 | Tablets & eReaders
New IVSO bluetooth keyboard - no instructions
How do I retrieve the password to complete the second part of pairing my keyboard!
Feb 02, 2014 | Dell Venue 8 Pro Tablet Computer
How do i connect my ipad to the hello kitty keyboard
After turning on your keyboard, the blue indicator light will come on for a couple of seconds, then go away. Next, press the button that says "connect" at the very top right corner of the keyboard. It looks like a wifi signal with a circle around it (I had trouble with this part, I didn't realize it was a button). Blue indicator light will start blinking, meaning that it's ready to connect. Go to Settings > Bluetooth (make sure it's on) > click on device. Voila!
Nov 29, 2012 | Hello Kitty Portfolio Case and Bluetooth...
TC1100 keyboard replacement info
If you are replacing the keyboard component (i.e. the actual keyboard) the process is straightforward. You will need jeweller screwdrivers as the srew (torque and philips are quite small):
1. remove all outside screws on the back of the keyboard
2. as per wkuk above you (thanks!) you will see 4 small covers
3. Pop the covers off with a pin they are lightly glued on
4. Remove the 4 screws (philips head)
5. Turn the keyboard so the keys face the table
6. Separate the case exposing the back of the keyboard
7. There are two screws that need to be removed that hold the keyboard in
8. Remove the tape that holds down the ribbon cables
9. Two ribbon cables attach the the keyboard. Be VERY careful and disconnext the slim one from the existing keyboard. Disconnect the second cable from the keyboard body (as the kew keyboard will plug in there.
10. Remove the keyboard and replace with the new keyboard
11. Reverse the steps above.
The real key is to be careful with the cables. Hold the entire cable firmly as these types of connectors can tear. When you initially slowly remove the cables you will gain some idea of how far the cable goes into the connectors. Although I've done lots of fixes on hardware this was my first time doing my keyboard for my TC1100 and the start to finish was 15-20 minutes. If in doubt, take a phot of the keyboard after you've removed the keyboard.
Cheers,
David
Jun 09, 2008 | Compaq tc1100 Tablet PC
Tablets & eReaders Logo
175 people viewed this question
Top Tablets & eReaders Experts
Marvin
Marvin
Are you a Tablet and eReader Expert? Answer questions, earn points and help others
