Can I get the TV to display the input from the composite ports in the front without using a remote? The TV powers on and tries to check for channels. Obviously it finds none, and then I'm stuck. No other buttons work except for the ones that make it try to find channels. Is there a certain channel I have to set it to that would be equivalent to "video 1" so I can get my game system to work?
SOURCE: My TV Says Line and Displays Just One Channel
Unfortanatly, your gonna need the original remote or a simular one to get to the channel programming mode in the menu. You can go to http://remotes.com or call 1-800-remotes and get one for your set. Im sorry i couldnt assist you more. Good Luck
SOURCE: play games on tv
go to channel 1 if there is no audio/video switch or you can use the rf mudulator
SOURCE: Tv Combo will not work with replacement remote
my panasonic tv model no. PV-DF2704, program light is blinking and I don't know how to cut it off. It is causing my tv to cut off. My remote control will not work. I bought it second hand. I program a universal remote and it works for a little while, but I can not set my tv for cable. Please help me if you can.
deborah from Louisville
SOURCE: Panasonic pv-c1350w channel/clock auto set
You are probably talking about the main menu that appears when the TV is taken off the AC power outlet, to get rid of this page just turn the tv off and on again and it should give you access to what ever channel was tuned before, if your game console has an RF out, your TV should be set to channel 3 ir 4, if the console has composite outs the change the channel until the TV goes to Aux in or Video in. Retrevo.com has an instruction manual available which you can download free, just in case you need more informantion, if the channel keys do not work, then you may have to get a universal remote ,they are fairly inexpensive and will come in very handy at least for the basic functions or just have theTV worked on.
