Question about Cadillac 2011 CTS 3.6L Performance w/ Navi
How do I reset the anti-teft alarm system? - Cadillac 2011 CTS 3.6L Performance w/ Navi
Posted by King James on
Claude Kayser
    Top Expert:
  • Cadillac Master
  • 9,098 Answers
How to reset an anti theft system on a Cadillac cts - Fixya
www.fixya.com/cars/t13766028-reset_anti_theft_system_cadillac_cts
Jul 26, 2012 - how to reset an anti theft system on a Cadillac cts - Cadillac 2005 CTS... After doing that and making sure the check engine is on you can do .... 2004cadillac cts 3.6 L Theft system locked. ... Nov 28, 2011 ' 2003 Cadillac CTS.
Re: Key stuck, won't crank, service anti theft HELPPPP ...
www.cadillacforums.com/.../cadillac-cts.../190779-key-stuck-wont-crank...
Jan 27, 2010 - 15 posts - ‎7 authors
I really want to do everything that i possibly can. ... Cadillac CTS First Generation Forum - 2003 - 2007 Discussion, Key stuck, ... The anti theft light comes on and the "service theft system" message comes ... for 30 minutes at a time to attempt to "reset" everything and still no luck. ... Automobile(s): cts 04,3.6L. Angry Service theft system, traction control light is on ...
Sep 1, 2013
Re: "starting disabled theft problem" HELP
Mar 7, 2013
Re: CTS won't start..Who likes a mystery and a long read ...
Jan 12, 2012
Angry Re: Car won't start-security System
May 25, 2010
More results from www.cadillacforums.com
[PDF]2011 Cadillac CTS/CTS-V Owner Manual
https://www.cadillac.com/.../Cadillac/.../2011_cadillac_cts_owner...
Cadillac
Posted on Jan 07, 2016
How do I factory reset my anti teft system for my 1999 ford explorer sport
Unless you have a ford factory scan tool , which costs $3,000 you don't . Dealer only !
Feb 08, 2016 | Ford Cars & Trucks
Anti teft
Normally you can lock and unlock the drivers door with the key to disarm the system.
Aug 25, 2012 | 2000 Chrysler Cirrus
How to reset anti teft on ford focus 2001
the soloution i have posted is a copy of my alldata book but it looks like it hasnt been censored as yet 10_4_2011_6_46_31_pm.tif
Oct 02, 2011 | 2001 Ford Focus
My BMW E30 1992 does not want to start. It sounds as if the anti theft code does bot want to disarm once one has put in the right code. So disconnected battery and waited fro 24hours reconnect battery...
Here is information on disarming the alarm! First you need to know if it is a factor or after market system! Here is how you tell if the headlights are flashing, the alarm system is factory installed. Inserting the key into the driver door lock and turning to the left then back to the right is supposed to disarm it. If the parking lights are blinking,, the alarm is an aftermarket add on, and there should be a disarm button under the dash on the driver side. If it' an aftermarket alarm, you should be able to have it removed. There is a way to bypass the factory alarm. There is a wiring harness in the driver's door. You will have to remove the door panel to find it. The wire is dark green and purple. Splice into that wire and ground it to the chassis and the alarm should no longer work
Jan 22, 2011 | BMW 325 Cars & Trucks
Ilost my keys, and had to have my car so i broke the ingnition houseing...to try and crank it...but when i try turning it over it is telling me something about the anti teft system and i should remove the...
you def messed up it needs the ignition key to bypass the theft system. without it you cant start it. replace the housing install a new ignition key and tumbler and have reprogramed to solve this problem
Jan 19, 2011 | 1998 Cadillac DeVille
1989 300e. The anti theft alarm went off while driving the car now the engine won't start. We shut the car off and locked and unlucked the doors several times. The alarm reset and we began driving again. A...
This is the problem due to your anti theft alarm system. You have not mentioned which brand of anti-theft alarm system you have? Anyhow, most of the systems have a reset switch inside the kit, open the kit and on the main board, u will find the reset button, press that and hold for 5 sec, the system will be reset. Otherwise, there are 2 or 3 fuses with the wiring of kit, remove those fuses and ur engine will wake up but the anti-theft system wont work then, hope this will solve the problem
Sep 19, 2009 | 1989 Mercedes-Benz 300-Class
Need to disconnect anti teft device. where is it located?
if you activate the anti theft on the jeep because of no remote,you have to lock and unlock the passenger side door twice to disarm it.
it is not easy to bypass the anti theft module.a place that installs alarms would be the best bet.get an after market alarm put in for about the cost of a couple remotes.or if you buy a used remote,it can be re programmed using the obd2 diagnostic unit.
Apr 20, 2009 | 1994 Jeep Grand Cherokee
Cadillac 2011 CTS 3.6L Performance w/ Navi Logo
724 people viewed this question
Top Cadillac GPS Experts
Marvin
Marvin
Tom Chichester
Are you a Cadillac GPS Expert? Answer questions, earn points and help others
