Question about Measuring Tools & Sensors
Why can't I receive input from the outside sending unit?
Posted by Chuck basich on
jhnolson
  • 822 Answers
Make sure that all the batteries are good!!
This procedure outlines the typical process to pair the sensor and base.
Base Station Battery Installation
·Remove the printed vinyl label from the LCD screen of the base station
·Position the remote sensor near the base station
·Open the battery compartment at the back of the base station and insert (2) AA batteries according to the polarity markings. Replace the battery compartment cover.
·Within a short time the RF signal icon (located to the left of the outdoor temperature channel indicator) will start flashing. This indicates that the base station is ready to pick up the RF outdoor temperature signal from the remote sensor. It will continue to flash for 3 minutes or until the signal from the remote sensor is detected.
Register the Remote Sensor
·Open the battery compartment at the back of the remote sensor and slide the channel selector switch to your desired channel. For the first remote you may select any channel, for additional remotes select any unused channel
·Insert (2) AAA batteries according to the polarity markings. Be sure to install the batteries in the remote within the time that the RF signal icon is flashing on the base station. 1541 WeatherGuide Wireless Weather Forecaster with Barometer
Posted on Jan 07, 2016
Claude Kayser
    Top Expert:
  • 9,098 Answers
01050C / 01055 AcuLink Weather Station - AcuRite® Official ...
https://www.acurite.com/kbase/01050C_01055_Weather_Station.html
Dec 14, 2015 - AcuRite Weather Station Display Console Instruction Manual 01050 / 01055 [PDF]. AcuLink Use Outside of the USA/Canada [PDF] ... Precision Forecasting... AcuLink can be setup to send email notifications that are received ... Can't activate... unit), try relocating the bridge by 3-4 feet to allow it to receive a ...
AcuRite Professional Digital Weather Station with Forecast ...
www.acurite.com > Environment > Environment - All
The AcuRite Professional Weather Station generates a weather forecast while ... The wireless outdoor sensor features 5 different technologies in one easy-to-mount unit:..... You can;t beat this type of customer service and we get American-English .... We do get high winds and I wish the 5-in-1 sensor would send the wind ...
BAR888A -Changed batteries house (1st) & outside unit(2nd.) Now inside unit not receiving signal. Only thing registering is inside temp. Outside unit is also showing temp.
Remove all batteries. Install batteries in outside unit and allow time for it to begin sending temperature. Install batteries in inside unit. You should see outside temperature displayed. If not, the outside unit could be defective.
Sep 25, 2018 | Measuring Tools & Sensors
No outside temp in de display only - - -in thedisplay i see the room temp. No outside temp. I have checked the outside transmitter end i see the red flash.
my unit tells me to insert fresh batteries into the outside sending unit first. then insert new batteries into the inside receiving unit. after the outside temperature shows up, then can reset my inside unit's time, choose F or C and
switch channels. please try changing channels if your
outside temp doesn't show. you can do both units in the house then put one outside after they work properly.
Mar 29, 2018 | Home
Barolo AU9 weather station. I replaced batteries in the outside temp unit. how do I activate it to show outside temp on the main inside unit
  • Remove batteries from both units
  • Install batteries in outside transmitter and wait for it to initialize and begin sending data
  • Install batteries in inside receiver and observe temperature reading
Sep 22, 2017 | Measuring Tools & Sensors
My sensor isn't sending signals to main unit for outside temperature .This unit is brand new and has new batteries
  • Remove all batteries from both units
  • Install batteries in sender. Allow time for sender to initialize and begin sending signal
  • Install batteries in receiver. You should see outside temperature displayed
Dec 29, 2016 | Measuring Tools & Sensors
Digital Audio Input isn't working
try to reset the receiver (note: all your settings will be lost) :
1 Switch off the unit using the main unit's power switch.
2 Hold the following SPEAKER A button and B button, and turn the main unit's power switch.
3 Check that the entire display is flashing with an interval of about 1 second, and release your fingers from the 2 buttons and the microprocessor will be initialize
assign inputs if necessory and check sound again. If no luck your receiver most likely has a problem with digital board and you need to send it to a repair facility.
Dec 18, 2011 | Denon AVR-785 Receiver
I have a picture but no sound
1. check input sound connection
2. check audio mute or not
3. check audio system in menu
4. check speakers (connect external speakers)
5. check amplifier IC bad or not
Aug 18, 2011 | LG Televison & Video
My acu-rite wireless thermometer model #00604RX isn't capturing the wireless sensor signal..both have new batteries and worked before changing old battery..reset the buttons too...help
Double check the batteries and the direction in which they are installed. If there is one backwards in the sending unit that is outside, it will not send a signal. Also, there is typically one battery in the indoor unit that is responsible for receiving the signal from the outdoor unit. If all of the batteries are in correctly except that battery, you will see the display, but will not get the data transmitted from the outside sending unit.
Sep 18, 2010 | Acu-Rite Acurite Wireless Weather...
Raynav 300 the gps is not working
The GPS antenna with the 300 is not a GPS receiver unit like all the later Raymarine units and is no longer made. However the unit will accept input from a GPS receiver with Seatalk output. So you could use a 112, 120 or 125 receiver.
May 02, 2009 | Raymarine Raynav 300 GPS Receiver
Multiroom not playing from 'DVD' source
Each input re[resents a zone, not a device. If your are lookin to seup multizones, each output controls one zone, ie - 1 = living room, 2 = outside, 3 = garage, 4 = pool room. If you are using a multidevice unit, the inputs must all go to one connector, input 1 = stereo, 2 = tv, 3 = xbox, 4 = pa.
Let me know if this make sense. If you have the make of the unit I will be more precise for you. I install these everyday, so this is easy.
Sep 25, 2008 | Marantz SR-7200 Receiver
Measuring Tools & Sensors Logo
1,589 people viewed this question
Top Measuring Tools & Sensors Experts
Marvin
Marvin
Tom Chichester
Are you a Measuring Tool and Sensor Expert? Answer questions, earn points and help others
