Mercedes-Benz 2000 S430 Logo
Posted on Jan 07, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Why won't it start?
Installed a new battery because the old one had a dead cell. The car started but had malfunction lights( ABS,electrical, ect.)I returned the car off and it wouldn't start. I unhocked the positive to let it reset. It started fine but with malfunction lights. I turned the car off and it wouldn't start.
Claude Kayser
Level 3:
Top Expert:
  • Mercedes-Benz Master 9,098 Answers
  • Posted on Jan 08, 2016
Claude Kayser
Level 3:
Top Expert:
Answers
9098
Questions
0
Helped
5067120
Points
28436
Mercedes Benz S430 won't start - 2001 ... - RepairPal
repairpal.com > ... > Mercedes-Benz > S430 > 2001 Mercedes-Benz S430
Dec 16, 2009 - I have a 2004 Mercedes Benz S430, the battery was dead, I jump started, I went out ... mercedes 2000 year s430 keyless remote won't turn to start the car? ... Something draining battery; replaced it but no start if not started daily. afterchanging the crankshaft position sensor I hear a metallic sound taking off.
jumping off battery on s430 mercedes will not start car.Is ...
www.cargurus.com > Questions > Mercedes-Benz > S-Class
CarGurusJun 3, 2014 - need a jump can't get in trunk to the battery 2000 s benz 6 answers ... I got the battery replaced and all the lights and radio will come on but still no luck. ... MyMercedes 300E won't start not long after getting a new battery.
s430 wont start...help!!!!!!!!!!! - Mercedes-Benz Forum
2003 Lincoln Town Car Issues
The simplest things can cause the most trouble - I would start with a load test on the battery - may seem to be charged after using a battery charger, but can have plate connection problems causing failure under load.
04 model starts ok battery charge light appears then ABS malfunction I drive short distance turn engine off when I turn on just clicks I can try again and starts no bother then same thing happens
Your battery charging system is defective, the battery is going dead and that is the cause of the other issue like the ABS light. Get the charging system diagnosed.
Battery light is on ABS light is on ,radio is off and rpms are stuck and my car wont start
You have a Malfunction Light on
ABS Light --- that is not something new
to anyone,check for codes as always
Most likely need professional scan tool
to access the abs module, so you also need
a repair shop as always
Check the battery for the no start
I have a problem with a 2008 Dodge Charger, my battery went bad and I had to jump it off to take it and get a new battery put in but now my new battery won't start my car not even when the new battery...
When you jump started the vehicle, it started as normal and you drove to a shop to have a new battery installed.?? Correct??
1. Who removed the old battery and installed the new one?
2. Did the car start normally immediately after the new battery was fitted? How frequently were you able to drive the car on the new battery before the problem you described appeared?
3. Has anything been done to the vehicle since the new battery was fitted.?
1999 Windstar drives fine for awhile then something starts to happen the abs light comes on the trak light comes on the lights won't go hi and low no backup lights the turn signal won't turn o
Just as a precaution, please check the brake fluid reservoir on that model. There is a sensor at the base of the master cylinder which can leak brake fluid over the wiring circuit, and cause the electrics to short out. In some extreme cases this has caused fires in some vehicles. This is why Ford had issued a recall to this particular model in the states at least.
2answers
Electrical Problems
HAVE THE BATTERY LOAD TESTED BY ANY AUTOZONE OR ORILEY AUTO PARTS, IT IS FREE. All THE SYMPTOMS YOU HAVE ARE FOR A DEFECTIVE BATTERY.
94 jeep hard to start like battery is weak
starter cannot act good if it does not spin the engine over quickly with new battery
pull it for a bench test under load
check and clean terminals and check for good ground point
1helpful
3answers
Electrical power system service required.....ABS warning light, generator warning light, brake failure...car stalled and wont't restart
usually caused by failed generator. Fix the generator and other lights will also extinguish. The car should jump start, but will not stay running without a charged battery. Recommend removing the generator and take to parts store for testing. Would you like instructions for removing generator?
Top Mercedes-Benz GPS Experts
ADMIN Andrew
ADMIN Andrew
Simon Atkinson
Simon Atkinson
Are you a Mercedes-Benz GPS Expert? Answer questions, earn points and help others
