Question about Sony KDS-R60XBR1 60" Projection HDTV
I need a copy of the Service Menus and Codes manual for this TV. Would you have it?
I HAVE CHANGE MY TV EPROM I NEED TV CODE TO SETUP
NOTICE: MUST READ BEFORE USING SERVICE CODES!!! RiddledTV.com provides this information for those that are qualified and trained to do TV repair work. Entering or making changes in service mode by untrained persons can cause significant and permanent damage to your television. If you are not qualified to service your television, please DO NOT ENTER these service menu codes. * Unplug the power cable. * Press and hold the {MUTE} button on the remote control while plugging the power cable back into the outlet. * Keep pressing the {MUTE} button until the TV powers on with the Service Menu displayed. * Use the {CH+} {CH-} buttons to select menus. * Use the {VOL+} {VOL -} buttons to change settings. * Some menus might have sub-addresses. Use the numeric buttons {0} to {7} to adjust sub-item data. * Press the {MENU} button or turn the TV off to exit.
Aug 06, 2012 | Televison & Video
Need codes for all for one URC4700BOO remote control for panasonic tv
Try the Panasonic TV codes: 0250, 0051, 0055, 0162, 0226, 0338 .
One for All remote manuals and code lists are available here: http://www.oneforall.com/support/manual . Select Universal remote control and the model in the drop down menus. The manual for the URC4700 is available here: http://www.oneforall.com/uploads/support/e04d2cffae9469f511770f5e563d5330.pdf .
Please note that the codes in a universal remote are limited to those for devices released 6 months or more before the remote was programmed. If your TV is newer than your remote, you may need a new remote. (The manual for the URC4700 has a copywright date at 1998.)
I hope this helps.
Oct 04, 2011 | Panasonic Televison & Video
NEED set up CODES FOR MAGNAVOX TV
Many One-for-All remote manuals and code lists are available here: http://www.oneforall.com/support/manual . Fill in Universal Remote Control and then the model number in the drop-down menus. Then click on the link to the manual. (It's a pdf so you'll need Adobe Reader or a similar program.) The direct link to the URC-6131N manual (English version) is http://www.oneforall.com/uploads/support/9e15c67cf9731f8b8e9b376352f23493.pdf .
Try the following codes: 0054, 0030, 0179, 0024, 0186, 0187, 0386, 1254, 1454 for Magnavox TVs. Please note that universal remotes usually only have codes for devices released at least 6 months before the remote was programmed. If your TV is newer than your remote, you may need a newer universal remote. The URC-6131 gives it a date of Feb 2003.
I hope this helps.
Sep 22, 2011 | Universal Remote Control URC-6131N Remote...
Dont have tv codes
Need remote codes for urc-3220 one for all
Jul 03, 2011 | One For All URC-6011 Remote Control
Need all in one remote urc3021 code for dynex tv
Do you mean a One For All URC-3021 remote? The manual and code lists are available here: http://www.oneforall.com/support/manual . Enter Universal Remote and then the model in the drop down menus. The direct link for the URC-3021 manual is http://www.oneforall.com/uploads/support/00a1e876ce84e35c2c0351a407218d66.pdf .
The Dynex TVs are usually made by LG/Zenith. You can try the Zenith codes: 0017, 0463, 0178, 0092 .
However, universal remotes are usually limited to having only codes for devices released 6 months or more before the remote was programmed. If your TV is newer than your remote, you may need a new remote.
I hope this helps.
(the URC-3021 remote manual has a 2004 copyright date.)
Jun 28, 2011 | One For All URC-3021 Remote Control
I need a code for my tv and it is a zenith
For a Zenith TV (not a combination unit) try the following codes: 0017, 0092, 0178, 0463, 1265 . Please note that universal remotes are limited to codes for devices released 6 months or more before the remote was programmed. If your TV is newer, then you may need a new remote.
The manual for the URC4220 is here: http://www.oneforall.com/uploads/support/8210f6981b8d184d890a27645d6c32df.pdf . If the direct link doesn't work, try here: http://www.oneforall.com/support/manual and select Universal remote control and URC4220 in the drop down menus.
I hope this helps.
May 19, 2011 | One For All URC4220 Remote Control
WHAT IS CODE FOR TV SANYO?
Hello
If you wants to get into the service mode of Sanyo TV. do one moung the folloing procedure. If you are in need of universal remote code for Sanyo follow the extented solution. Your post is not clear, that is why I answers for both.
To get in to the service mode adjustments
[1]
[OR]
* Press and hold the {VOL -} button on the TV
* Keep pressing the {VOL -} button until
Universal remote codes:
Three digit universal remote code for sanyo are:
004/ 013/ 049/ 108/ 110/ 180/ 209
Four digit universal remote code for Sanyo are:
0049 0097 0110 0004 0268 0012 0108 0180
Direct Code Entry
  1. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  2. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks, then stays lit.
  3. Enter the 4 digit code from the code tables. Note: after a valid code entry, the red indicator turns off. For an invalid code, the red indicator flashes.
  4. With your device on, press CHANNEL UP. If the device responds, no further programming is required. Note: If some buttons do not operate your device, try one of the other codes for your brand.
OK.
Jan 25, 2011 | Televison & Video
Help to program tv
On the web page link below you will find the RCA Customer Support website page with all the service information for your model RCA 3 device universal remote control model number RCR311S. On this page is a pdf copy of the owners manual. You will need a pdf reader and writer to read the owners manual and a writer to make a copy for your own use.The information you are looking for is on pages 4-12 in the owners manual. I hope this information solves your problem of finding a copy of the remote control owners manual. Thank you for using FixYa and have a nice day! /RcaaccessoriesProductDetail.do?ACTION_TYPE_ID=ACTION_TYPE_PRODUCT_DETAIL&http://www.rcaaccessories.com/rcaaccessoriesACTION_CATEGORY_IDSTR_CATEGORY_UNIVERSAL_REMOTES&ACTION_PRODUCT_ID=RCR311S
Jun 15, 2009 | RCA 3-Device Universal Remote with...
Service menu instructions needed
service menu code is 9876, i think. and you can manually adjust the focus using network54's post on "blurry z27x22d".
Sep 16, 2007 | Zenith Z27X22D 27" TV
Service menu
Turn television off and then hold ch - and vol - on the tv, not remote, for about 10 seconds and it will come back on with service menu up. There you can change alignment.
Apr 19, 2007 | RCA HD52W59 HDTV Projection Television
Sony KDS-R60XBR1 60" Projection HDTV Logo
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Ekse
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
