SOURCE: Perform Service Light comes on
This is a setting that can be reset to 2000 miles - when it counts down to 0 you get the "Perform Service" alert. I believe if you use the Step function you will see "XX miles to Service" Use the reset button to set this back to 2000.
SOURCE: How to remove the right rear door panel on a 2005
you need a tool pry the panel from clips. you need a haynes manual to tell you where all your screws is located to move door panel.
SOURCE: Where are the spark plugs located in a 2005 Chrysler Pacifica?
Jay from Ma,
You have it backwards the rear three are accessable with the front three being under the intake. To remove the intake simply remove throttle body and aproxamently 15 other bolts.
SOURCE: program instruction garage door opener in 2005 chrysler pacifica
if your garage motor have rolling codes you need to put your car inside garage near the motor leave ignition on go to the motor locate learn button press it then quickly go to the car and press and hold one of the buttons for approximately 30 sec or until it start blinking rapidly, if you have a regular motor take one hand held opener go inside car ignition on same time press open button on handheld remote and on the car button 30 sec and it should be programmed.
SOURCE: where is the oil sending unit located on a 2005
Welcome to FIxYa.com Right above the oil filter Thank you for using FixYa.com Regards, Lee Davidian
