Left grouphead is not putting any water out. Pump engages, water is dispensed into drain tray from overflow tube?? But no water through grouphead..I removed screen and sprayhead plate? neither are clogged and are clean. The drain tube? keeps dispensing water into drain tray even after you turn off grouphead and constantly is discharging a small flow of water into drain tray. Any suggestions where to start troubleshooting?
SOURCE: Pump keeps running and excess water goes into the cup tray
check the level probe on side of boiler may not be facing down as it should or need to be replaced.
SOURCE: water wont stop dispensing Nuova Simonelli JAZZ Espresso
Hello. We had the same problem, after about 20 cups, the hot water would not stop running out the steam nozzle. The problem is either a faulty Solenoid or a blockage stopping the solenoid from closing. We ran the steam for 5 seconds, then stopped, then steam, then stopped, then water, then stop, and it seemed to clear the blockage. Alternatively, you may need to get the solenoid replaced.
SOURCE: How do you clear a
if it is solenoid it can be from the un-cleaning with detergent&blind filter, to provide longer life of new valve you should purchase them and clean with them periodicaly.
