Question about HP Computers & Internet
What's your question? my hp compaq nc6320 automatically restart after i shut it down....pls how do i fix it
Posted by Ambs frosh on
How do i fix a problem of green power led continuously blinking in Hp compaq nc6320 laptop even when the battery is removed and the motherboard is outside the case?
HP Notebook PCs - Troubleshooting LED Blink Codes or ...
h20564.www2.hp.com/hpsc/doc/public/display?...na...
Hewlett?PackardHP Notebook PCs - Troubleshooting LED Blink Codes or Beep Codes During Startup or Boot ... HP Pavilion and Compaq Presario notebook computers built in 2009 or later use blinking LEDS to identify ... Press the power button to turn on the computer, and look for blinking LED lights on the keyboard. ... Continuous blink.Missing: green ‎nc6320
HP Notebook PCs - Computer Does Not Start and Emits an ...
support.hp.com/us-en/document/c01732674
This document pertains to HP and Compaq notebook computers. .... light next to thepower socket or the light on the AC power adapter and note its condition: off, blinking, or constantly on. ... Battery power LED off, and Caps Lock/Num Lock off.Missing: green ‎nc6320
HP 6735s won't boot, power LED blinks 7 times - HP ...
Feb 03, 2016 | HP Computers & Internet
I cannot find any printscreen or prtsc button on my (second hand) HP compaq nc6320. Can I make one with quickbuttons or so ..?
You should have a blue [fn] button to the right of the [ctrl] key. Hold it down and press [insert] at the same time. My NC6320 has lots of these functions printed in blue on the keys.
Hope this helps!
Apr 08, 2011 | HP Compaq nc6320 Notebook
Is it compatibløe with Windows 7?
It does not have any Windows 7 drivers on the HP page so some parts may not function. Windows 7 usually discovers and installs most of the drivers automatically however you cannot be quaranteed that everything will run smoothly.
You can check your system with the Windows 7 Upgrade Advisor.
Download it from here:
Feb 01, 2010 | HP Compaq nc6320 Notebook
Laptop mouse pad doesnt work if being used on flat surface
Power drain would be a better solution in this case.
1.first shut down the comp
2.unplug the charger
3. remove the battery
and after press and hold the power button for 60 seconds without any charger and the battery.After the 60 seconds replug the battery and the charger and turn the computer .
Oct 27, 2009 | HP Compaq nc6320 Notebook
Pls i need video controller driver for compaq nx61110 notebook
go to www.hp.com. Select drivers and download and download the Motherboard driver anfd the necessary driver desired by you.
Thanks
Jan 26, 2009 | HP Compaq nc6320 Notebook
My hp compaq nc 6320 is running at 987mhz
I believe the Centrino Duo steps the processor down to save energy when unplugged. Try restarting the computer with it plugged in (if it isn't plugged in now). You might be able to change or disable this function in the power management program if this turns out to be the issue.
Oct 07, 2008 | HP Compaq nc6320 Notebook
Describe your HP Compaq nc6320 PC Notebook Problem
i have a Compaq nc6320 when i plug in the power cord the electricity led doesn't want to turn on i have changed the cords and the adapters and i doesn't power on or even charge the battery, did any one have an idea what to do in this problem?
Mar 31, 2008 | HP Compaq nc6320 Notebook
Computers & Internet Logo
50 people viewed this question
Top HP Computers & Internet Experts
Lee Hodgson
Lee Hodgson
Muntejaya Ginting
Muntejaya Ginting
efs_perpends
efs_perpends
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
