We have very hard water, but I try to descale regularly. I've run three cleaning cycles, thinking it's lime stuck in the pipes, but nothing's worked. Can anyone help?
SOURCE: zojirushi ns-zcc18
Download instructions from http://www.zojirushi.com/servicesupport/manuals/index.html
SOURCE: How do I clean the Hot Water Dispenser?
I have zojirushi 4L (model: CD-LCC). I noticed that the bottom of the pot have some stain which are looked like "corrosion". What should I do? How to remove it? Please help.
Thank you
SOURCE: I just poured water from
Fill it with vinegar and leave to soak overnight/for two nights if really bad.
Any parts which are impossible to fill with vinegar - lids/spouts, soak a cloth or tissue in vinegar and wrap/wedge into....and leave to soak overnight.
SOURCE: On my Zojirushi CD-LCC30 when I press the unlock
I called 1-800-733-6270 (taken from http://www.zojirushi.com/servicesupport/manuals/manual_pdf/cd_lcc.pdf). The rep was very helpful. She suggested that there was probably residue stuck in the tubes. She suggested that I use citric acid solution and put it through a cleaning cycle. After the cleaning cycle, do not pour out the water immediately. Instead, dispense the water through the Dispense button, to clear out the tubes. It worked. I had just gone through a cleaning cycle before this problem happened to me, and gotten rid of big chunks of "crud" (especially the build-up around the filter).
