This model has no visible filters to clean/change, and does not have the plug type filters on bottom of drum/under agitator. I have a cat & dog and after washing anything they've been in contact with the inside of washer/drum/agitator are all covered with hair, from top to bottom. I'm assuming this hair and whatever else should have gone down drain?? So if hair is there and shouldn't be where do I look for what's not working right? Somebody help me please....
Usually the dogs in the upper agitator go bad. your agitator is two pieces. grab the lower agitator and turn the upper agitator. if you can turn it, the upper, back and forth. the dog cams are bad. very common problem. if they are stripped, clothes will not agitate in wash or rinse. plus machine can go out of balance easy. usually caused by normal wear and tear but is also a sacrificial piece in the even of an overload. common tools repair. good luck.
Kihm Skillicorn
SOURCE: GE WHDRR418G1WW Washing Machine will not agitate or spin/rinse cycle
The ge wcxr1070t uses a coupling under the agitator . There is a cap on the top pop it off and remove the screw if you see one , otherwise just pull up , the coupling is under the agitator check to see if it is stripped . dr fixit in the repair service directory will have it if bad
SOURCE: Kenmore 80 Series Top Load Washer not agitating
Check out this you tube. Had the same problem today. Tipped washer on its side and replaced coupler between motor and gearbox. Parts are about $15
This is a good diagnosis video.
http://www.youtube.com/watch?v=VYOP0_KCYT0
SOURCE: Kenmore 80 series top load washing machine won't agitate or spin
defective motor coupling,,replace..onthejob
SOURCE: kenmore 80 series washing machine agitator will not rotate
you need to replace the agitator dogs, very simple. Go to www.shop.washermd.com and download the tutorial, thanks
