Question about Kenmore Elite Hybrid Water Softener Gray More than 6
How do I reset the time?
Pressing SELECT button does nothing.
Dennis
    Top Expert:
  • 1,052 Answers
Very common with this type of unit. The switches are prone to corrosion and failure. You can buy a new timer from Sears (~$150) or off Ebay (~$100), or use a simple, no tools procedure, I use on my Sears softener.
-Unplug the softener.
-Carefully remove the top cover from the softener (usually 2 tabs in front and 2 in back).
-remove the timer panel (mine is held on by 2 tabs, one on each side).
-unplug the wiring to the timer.
-remove the timer (mine is held in place by a little plastic hook at each corner, remove one side and first and then the other.
-with the timer out, you can see the switches. while pressing on one of the switches, move your finger in a circular pattern (this rubs the contacts together on the inside of the switch, allowing the contact material to "grind" through the corrosion). Do this with all the switches.
-to reinstall, reverse the processes.
Posted on May 17, 2016
My toshiba excite 16gb 10 hd sku:7360TT2 it wont let me connect to wi-fi what can i do i factory reset nd nothing
The solution is a factory reset....I know you mentioned you have done this but did you follow this method?
1.Make sure the tablet is off and not in standby.
2.Hold down the 'Volume Up' and 'Power' buttons simultaneously until the two Android icons appear.
3.Use the volume buttons to select the white box on the right.
4.Once selected, press the power button.
5.Use the volume buttons to select 'wipe cache partition' and then press the power button.
6.Select 'Yes' and press the power button.
7.Use the volume buttons to select 'wipe data/factory reset' and then press the power button.
8.Select 'Yes' and press the power button.
9.The tablet will now reset.
Feb 04, 2015 | Toshiba Tablets & eReaders
Control locked button is on and whatever button i press nothing works. it is KitchenAid KHWS02RMT3 front load washing machine.
I don't know if this will work but try it...
Select PAUSE/OFF twice to cancel the cycle.
Select DRAIN/SPIN if there is excessive water in the washer.
Re-select cycle and press HOLD TO START.
Let me know if no response.
Jan 20, 2013 | Washing Machines
I have been using a Sunbeam Model 5891 Breadmaker for over a year without trouble. Today I loaded the machine like always and selected the settings I usually set and hit go. Nothing happened. The lights...
The Sunbeam 5891 is a disposable type for there are no user-servicable parts.
Here's more:
Addressing Power-up/Start-up Issues:
1. Unplug the breadmaker.
2. Confirm the power source you're accessing is live using a blender, toaster, etc.
3. Plug the breadmaker in.
4. Confirm the breadmaker is receiving power:
    1. Some models have a built-in off/on switch. Turn it to the ON position.
    2. Some models make an audible tone when plugged in.
    3. Some models have a colored light and/or a lighted display screen that lights up.
    4. Some models require you press the Select button down until the unit powers up.
    5. Some models require you press the Start button down until the unit powers up.
    6. Some models require you press the Select button first to select a mode, then press the Start button.
3. No, you were not able to confirm that your breadmaker is receiving power? Sorry to hear that. Attempt to have the breadmaker serviced by a small appliance repair facility or simply discard it.
4. Yes, you have confirmed that your breadmaker is receiving power? Fantastic! Now reboot the breadmaker's electronics by pressing down continuously on the Start button until you notice a visible and/or audible confirmation, usually within 5 to 10 seconds. Beware: Some models require you press the Select button first to select a mode, then press and hold the Start button to reboot the system.
That should fix it. Hope this helps!
Special Note: Often the + and - Timer Delay buttons are pressed by mistake, delaying Start by up to 12 hours. If you suspect the Timer Delay feature has been engaged accidentally, you'll need to reboot the breadmaker's electronics. You can do this by pressing down on the Start button continuously until you notice a visible and/or audible confirmation, usually within 5 to 10 seconds. Beware: Some models require you press the Select button first to select a mode, then press and hold the Start button to reboot the system.
Jun 17, 2011 | Sunbeam 5891 Bread Maker
Hey i've had my galaxy s2 for a week today, trouble is i've forgot my samsung password and when i click on the link it sends me an email but it dont go to the reset or anything nothing happens
PRESS AND HOLD VOLUME UP + Home Button
Keep pressing these 2 buttons + press Power button for 2-3 Seconds
Release only power button, but KEEP pressing Volume up + Home Buttons
With Volume down select wipe data/factory reset (3rd) > Press Power
or
Turn off the i9100 S 2 phone or take out the battery and reinsert it.
Hold the Volume Down button
Press and release the Power button
Select Clear Storage by pressing the Volume Down button
Press Volume Up to confirm i9100 master reset
May 28, 2011 | Samsung Cell Phones
Received new DirecTV HR-21-100 PVR, tried to set up device in remote, now nothing works
Your DirecTV device is probably set on RF (Radio Frequency), which the Harmony can't use. You will need to set it to IR (Infrared) for the Logitech remote to control it.
1. On the original DirecTV remote press the Menu button
2. From the Menu press Select on Settings
3. Select Remote from the left menu
4. Press Select on the IR/RF Setup button
5. Use the Up or Down arrows to change from RF to IR
6. Press Select to save
May 20, 2010 | Logitech Harmony 670 LCD Remote Control
HP LaserJet 3055. All of a sudden it stopped working. after powering up, it does "nothing" HP appears in the menu window, but that's it. none of the keys works, no way to even test it. All cables are...
Perform a cold reset
  1. Turn the printer on.
  2. Watch the control panel.
  3. When the memory starts counting, press and hold the green c00007906.gif (Select) button. Continue to hold Select button until all three Control Panel LED's are illuminated and on solid.
  4. Release the c00007906.gif (Select) button.
  5. The control panel will display SELECT LANGUAGE .
  6. Press c00235041.gif (Down Arrow) button until control panel displays COLD RESET .
  7. Press c00007906.gif (Select). The printer will perform a cold reset and then continue its power-on sequence.
Dec 14, 2009 | HP LaserJet 3055 All-In-One Printer
Samsung LE32R7 will not retune since switchover
Updating the Channel List Automatically You can update the channel list when the broadcaster adds new Services or if you move the TV to a new location.
1. Press the MENU button to display the menu. Press the ▲ or ▼ button to select "Digital Menu", then press the ENTER button.
2. Press the ▲ or ▼ button to select "Channel", then press the ENTER button.
3. Press the ENTER button again, to select "Country".
4. Select the appropriate country by pressing the ▲ or ▼ button. Press the ENTER button to confirm your choice. Even though you have changed the country setting in this menu, the country setting for Analogue TV is not changed. (Refer to page 11 of the user guide)
5. Press the ▲ or ▼ button again, to select "Auto Store". Press the ENTER button. When it has finished, the number of scanned services will be displayed. The existing favourite channel list will not be deleted when the channel list is updated. To stop the scan before it has finished, press the ENTER button with "STOP" selected.
6. Press the EXIT button to exit. If the signal status is poor, the "No Service found! Check the aerial connection" message is displayed. Check the aerial connection and the try the procedure again
Sep 30, 2009 | Samsung LE32R74BDX 32 in. HD-Ready LCD...
MX310, says receiving fax but nothing comes out.
michael885 -
Your unit has a certain amount of memory designed to store faxes... if they are stored there, here are the instructions for retrieving the fax's from the memory:
(I found this at: http://safemanuals.com/annexe_MX310%20series%20Easy%20Setup%20Instructions_CANON_PIXMA%20MX310-_E.htm
�� Printing a List of Documents in Memory
The machine can print a list of documents stored in memory (the memory list) showing the
transaction number (TX/RX NO.), transaction mode, recipient, number of pages, date, and
transmission time of each document. When printing or deleting documents in memory, specify a
document by its transaction number.
1 Press the FAX button, then press the Menu button.
2 Press the [ or ] button to select MEMORY REFERENCE.
3 Press the OK button two times.
The memory list is printed.
�� Printing or Deleting a Document in Memory
3 Press the OK button.
Hope this helps!
-- RT
PS - If useful, don't forget to vote!
Aug 02, 2009 | Canon PIXMA MX310 All-In-One Printer
Screen stays black after closing and then opening Inspiron 6000
you try pressing the power button once?  or maybe even pressing any keys.
also try adjusting your power management
vista) start. control panel. power option.  Edit plan settings.
xp) right click anywhere.  properties.  screen saver tab.  power management.
Mar 09, 2009 | Dell Inspiron 6000 Notebook
Need to change my Crown CDV 1100B player to multi region, have tried recommended options from other sites, but to no avail. This what I've tried so far. 1) Press set up 2)press 1369 (which was...
a) Press SETUP button on the remote control to display the setup
screen
b) Press "1369<<<>" on the remote control ( "<" = left navigation
button; ">" = right navigation button)
c) A new item "VERSION" is added on the menu
d) Select thr VERSION item and press SELECT button to enter
e) Press the right navigation button ">" on the remote control to
change the region code
f) Press SETUP button again to exit the region code change mode
Note: Region code 0 is "all region code".
OR
1.press eject to open the draw.
2.type 9-8-1-7.
3.press select to go through regions.
4.change to region 9 for multi region.
5.press eject to close the draw.
OR
1. Press the Open/Close button on your remote control to open the drive tray
2. Press the 8, 4, 2 and 1 buttons on your remote control, in order, one at a time
3. Press the Enter button on your remote control until the hidden menu appears
4. Select 1 for region 1, 2 for region 2, and so on, or All for multi-region
5. Press the Open/Close button on your remote control
To alter the Macrovision settings on this player
1. Press the Open button on your remote control to open the drive tray
2. Press the 4, 5, 6 and 1 buttons on your remote control, in order, one at a time
3. Select Enable to enable Macrovision, or Disable to disable Macrovision
May 03, 2008 | Televison & Video
Kenmore Elite Hybrid Water Softener Gray More than 6 Logo
1,193 people viewed this question
Top Kenmore Water Dispensing & Filtration Experts
Bill Boyd
Steve Pack
Steve Pack
john h
Are you a Kenmore Water Dispensing and Filtration Expert? Answer questions, earn points and help others
