Question about Sharper Image Drink-O-Matic
My green light flashes but fan does not spin and it does not cool. any advice?
Model D-R3
Claude Kayser
    Top Expert:
  • Sharper Image Master
  • 9,098 Answers
Drink o matic power cord Questions & Answers - Fixya
www.fixya.com > Forum > Tags
Get free help, tips & support from top experts on drink o matic power cord related issues. ... the drink o matic? the green light wont turn on on the back. the fan wontturn ... stopped working Hi, I have a Smart Planet Drink-O-Matic model # DR3. ... The machine does not cool. ... I have the same machine, my power supply was .
[PDF]UNIT 5 TROUBLESHOOTING - Bunn
www.bunn.com/.../troubleshooting.pdf
Bunn?o?Matic CorporationGiven a realistic scenario when product does not freeze or chill, the learner will be able to ... The learner will be able troubleshoot the torque (ice) system.Missing: sharper ‎image ‎green
[PDF]Operating, Service, CDS-2, CDS-3 Operating ... - Bunn
www.bunn.com/sites/.../27646.0000.pdf
Bunn?o?Matic CorporationTo obtain the Illustrated Parts Catalog, visit the Bunn-O-Matic website, at www.bunn.com. .... In no event shall Bunn be liable for any other damage or loss, including,but not limited ... NOTE - Bunn-O-Matic does not recommend the use of any extension cord .... THREE QUICK FLASHES - Low auger torque is being sensed.Missing: sharper ‎image ‎my
Free Kitchen Appliance User Manuals ' ManualsOnline.com
kitchen.manualsonline.com/
Posted on Jan 05, 2016
I have a red and green light flashing, fan work on inside but unit will not come on outside
There should be a diagram on cover that also show you what codes the flashing lights mean. I will need the model number of your outdoor unit to tell you what the lights mean.
Jun 06, 2017 | Heating & Cooling
Greetings Gurus. I have Makita charger model DC18RC, battery model is 18v BL1815...manual is of limited help. I'm trying to understand what the indicator lights mean, what the time is for charging,
I agree that the pictographs are not very helpful. You probably have one of the new chargers. I have an old one, which is a little easier to figure out.
From top to bottom
1. The flashing green light with the electric plug indicates that the unit is plugged in and ready to go.
2. The flashing red little fan means that the battery is too warm so it is just cooling it and not charging it at that moment.
3. The solid red empty battery outline means that it is charging but hasn't got very far, less than 80% full.
4. The mostly full battery outline with both solid red and green lights at the same time means it is 80% full or more
5. The full battery outline and solid green with the musical notes means it is full up.
6. The broken battery outline with flashing red and green means you've got a broken battery.
7. The yellow light with the wrench means the charger is "conditioning" the battery, whatever that means.
8. The yellow light with the fan means "cooling abnormality."
Hope this helps
Nov 01, 2014 | Drills
Samsung DLP hlp5063wx/xaa - Cycles through the warm up 2 times but does not turn on, then 3 lights flash on the front (2 green, 1 red) Bulb is new and looks good, fans seem to be spinning freely. Any...
If your having the "3 light" problem it could be an indication of a bad lamp however if there is a buzzing or a grinding sound it could be one of two moving parts. The color wheel or the cooling fan. I would go the cheaper route and replace the color wheel first since you say the fan is spinning. The thing is the lamp will not turn on if there is a problem with one of the other two parts. The motor on the cooling fan is too small for such a big fan so I would definately try it next. It's a big problem with the DLP tvs. good luck!
Feb 14, 2011 | Samsung Televison & Video
Green led indicator light is off on my 62" toshiba
when you turn it off your light blinks because your internal fans are still spinning allowing the inside of the chassis to cool off, hence the reason you dont watch a DLP TV and then unplug it. DLP's are JUNK
Dec 01, 2010 | Toshiba 62HMX84 62" Rear Projection HDTV
My Vinotemp VT-12TEDS has no front panel lights or temperature reading. The unit flashes the red and green LEDs and clicks in sync with the flashes. The external cooling fans attempts to move, but does...
I also have the same problem and am looking for a solution short of buying a $35 replacement board with $10 shipping for a fridge that costs $60 new.
Oct 04, 2009 | Refrigerators
KDF60XBR950 doesnt turn on....fan is on just flashes green
There is no less than two Cooling Fans on the right side. Either one of them could cause the problem. The one that turns slow or stops turning quickly is the one that is probably causing the problem.
I hope this helps,
Sky Assoc
Sep 11, 2009 | Sony Grand WEGA KDF-60XBR950 60" Rear...
Vizio P50HDM No Picture/No Sound
this is most likely the sustainer board(s) problem. Replacing the sustainer boards should correct this problem for you. you can get the parts at vancebaldwin.com
May 29, 2009 | Vizio P50HDTV10A 50 in. Plasma HDTV
No picture or sound!
The bulb is bad my friend, even if it looks good, the flashing light is the first indication. You should get the original lamp from here http://www.samsungparts.com/part_detail.asp?catalog%5Fname=Parts+and+Accessories&product%5Fid=BP96%2D00224B Good Luck
Jun 29, 2007 | Samsung HLN617W 61" Rear Projection HDTV
Sharper Image Drink-O-Matic Logo
468 people viewed this question
Top Sharper Image Retail Supplies Experts
Electroboy
Electroboy
Marvin
Marvin
Are you a Sharper Image Retail Supply Expert? Answer questions, earn points and help others
