2004 Buick Century Logo
T
Toney Bozeman Posted on Jan 05, 2016
Answered by a Fixya Expert
Trustworthy Expert Solutions
View Our Top Experts
Will oil pressure sensor shut the car down - 2004 Buick Century
Jeff Armer
Level 3:
  • Buick Master 15,575 Answers
  • Posted on Jan 05, 2016
Jeff Armer
Buick Master
Level 3:
Answers
15575
Questions
Helped
7111391
Points
73899
The IPC illuminates the LOW OIL PRESSURE indicator in the message center when the powertrain control module (PCM) detects low engine oil pressure, and the signal circuit is low. The IPC receives a class 2 message requesting illumination message from the PCM.
No it can't shut down the engine !
No
1helpful
2009 GMC Denali shutting off while driving
check and test oil pressure sender --sender also has a micro mesh filter that cloggs which can cause shut down --also check when stalls if its fuel or spark --shutting down w/no codes their are a few reasons beside oil --coil -fuse --fuel pump--cam /crank sensor --cat converter etc
My 2003 mercury mountaineer truck Low oil pressure sensor light come on in shut the truck down in the truck still have oil in it
Low oil pressure sensor light will not shut off the vehicle . Newer vehicles yes , yours no . Have it checked by a qualified repair shop .
2answers
Will the oil sensor switch shut the engine down
Well, yes and no.
If the red oil pressure light comes on, yes the engine could stop running. You could actually lose oil pressure, or the switch could fail.
A "change oil" notice would not cause the engine to stop.
GM said the sensor by the oil filter on a 1997 achevia is a crank sensor you its a oil presser sw. and it is linked to Ign sw. how , will the eng die in a second if the wires are broken or the sensor
the oil pressure sensor tells the ECM when there is insufficient oil pressure to safely run the engine
when you start an engine there is oil covering the pump inlet and the pressure buils up
if there is insufficient oil to maintain pressure ,or the pump cannot maintain a low preset pressure , the ecm will shut the engine down to protect it
like wise if the wiring is loose /faulty the signal from the sensor is interrupted and that tells the ecm to shut the engine down
again if the sensor is faulty , the ecm will shut the engine down
how to fix :-
install a mechanical oil gauge in the system and check for oil pressure achieved
replace the sensor switch with a known good one
run the fault codes
1helpful
Will a oil pressure sensor circuit if bad, shut down your car?. 2007 Chrysler Aspen 5.7 hemi
Yes it would. If there is no oil pressure then the computer shuts down the engine. I believe all cars have that security now.
Oil light came on runs really rough and then shuts down. so far i replaced fuel pump, mass air flow sensor, oil pressure sensor and oil level sensor. nothing yet. no check engine light either.
Don't run the engine with the oil light on. No oil pressure means no oil circulation, and damage will result. Have a shop check the oil pressure with a gauge that plugs into the oil pressure sensor port. If no pressure, check if you need a new oil pump.
Will a faulty oil pressure sensor shut the truck down/2007 dodge ram 2500 5.7 hemi
Yes,here it is.http://www.autozone.com/autozone/parts/Duralast-Oil-Pressure-Switch/2007-Dodge-RAM-2500-3-4-ton-2WD/_/N-jq7tpZ8znc6?itemIdentifier=715966_0_8537_
2helpful
1999 Mercury Cougar Starts and then Shuts down. In the beginning the car had a rattle in the TimingChain cover and was checked and it was fine, just that the Oil pressure was low and then the lifters...
Most engines have a low pressure shut-off OR the lifters no longer work with lack of oil.
Have someone check the REAL oil pressure with a gauge.They can thread a gauge into the Oil pressure sensor hole.
Since the oil pressure sender COULD be bad,you need this true reading.
It should run just long enough to give a reading,I hope.
I don't know if the OBD II codes would show the oil pressure.UIt doesn't on my Focus.I hope you get `er going,but the engine must have at least 25 psi oil pressure.Have you replaced the oil filter? don-ohio
It shuts off by itself
You will need to inspect the correct operation of your oil pressure sensor. If your vehicle is running and shuts down by itself, then it may be getting a signal of low oil pressure. This shut's down the engine to prevent engine damage!
2000 saab 95 wagon,2.3t. oil pressure light came on. checked and filled oil, about 2 quarts. light did not go out. driving on highway, car shut down when check engine light came on. now car will only run...
Oil pressure sensor blocked or faulty. both oil level sensor and oil pressure sensor activate the oil light. engine goes into safe mode and shuts off ignition.
Top Buick Experts
ZJ Limited
ZJ Limited
Thomas Perkins
Thomas Perkins
Are you a Buick Expert? Answer questions, earn points and help others
