In other words do they have an adapter that plugs into the 9 pin and has a normal wall socket plug on the other end to power the CD player?
SOURCE: ac power cord for HP vf51 flat panel monitor
Good Day Tricia,
I had to pull up you owner's manual to get the spec's on your cord, so if you need the manual follow this link:
http://h10032.www1.hp.com/ctg/Manual/bph08231.pdf
Anyway after reading the spec's you need an AC-DC power supply that outputs 12volts at 3.3amps. What makes this difficult to find is the 3.3amps, most aftermarket power supply only go up to 2amps. So what's next? Well you can order directly through HP at this link:
http://partsurfer.hp.com/cgi-bin/spi/main?sel_flg=partlist&model=P4824A&HP_model=&modname=HP+vf51+15-inch+LCD+flat+panel+display&template=main&plist_sval=Power+Cord&plist_styp=subcat&dealer_id=&callingsite=&strsrch=&keysel=Power+Cord&catsel=%3F
If you do this make sure get part 8121-0740 if you live in the states, or part 8121-0731 if you live in europe.
The only other suggestion I can give is to bring the monitor into a radioshack and see if they have a 12VDC 3.3AMP (you can get a universal with higher amperage if needed, the monitor will only draw the 3.3 it needs even if it is supplied more) and the reason I say bring it in is so they can match the size of the plug that goes into the monitor, as there are about 20 diffrent diameters's. Again the problem you may have is finding one with a high enouge amperage.
I hope this helps
Good Luck
SOURCE: need power cord tranformer for my computer speaker
you'll need electrical specs of the transformer (current and polarity) for the speaker system and mechanical connector spec. At the very least a model and number.
SOURCE: HST-221 Sony Stereo Component system - Lost System Control Cable
This is a long shot go to www.ebay.com Type: make and model and scroll through the listing.
