A/C works fine
Hello J, thanks for your post!
I see that your Frigidaire air conditioner is not emitting the proper air when in heat mode. I would recommend performing a reset on your air conditioner and you can do that by disconnecting the power cord. Once you have removed the power cord, press the reset button and then the test button. You should then be able to plug it back into the wall and start it up. If you continue to have issue with it an electrical component may need to be replaced and I would recommend this be completed by a professional technician. They would have the knowledge on how to properly disassemble the air conditioner without any harm. Good luck! -Matt
