Question about Taylor Measuring Tools & Sensors
Replaced batteries, outsid temp. does not display
Posted by Ronnie Gaskins on
  • Ronnie Gaskins
    Ronnie Gaskins Jan 06, 2016
    Had to do it a couple times, came on.
jhnolson
  • 822 Answers
Base Station Battery Installation
·Remove the printed vinyl label from the LCD screen of the base station
·Position the remote sensor near the base station
·Open the battery compartment at the back of the base station and insert (2) AA batteries according to the polarity markings. Replace the battery compartment cover.
·Within a short time the RF signal icon (located to the left of the outdoor temperature channel indicator) will start flashing. This indicates that the base station is ready to pick up the RF outdoor temperature signal from the remote sensor. It will continue to flash for 3 minutes or until the signal from the remote sensor is detected.
Register the Remote Sensor
·Open the battery compartment at the back of the remote sensor and slide the channel selector switch to your desired channel. For the first remote you may select any channel, for additional remotes select any unused channel
·Insert (2) AAA batteries according to the polarity markings. Be sure to install the batteries in the remote within the time that the RF signal icon is flashing on the base station.
1541 WeatherGuide Wireless Weather Forecaster with Barometer
Posted on Jan 05, 2016
My atomic clock does not read outside temp
Bring outside temp sensor indoors. Remove batteries from both remote and base. replace outside first with fresh batteries (Alkaline recommended). Then the base. Make sure they are on the same channel. When display restored, you can take the remote back outside.
Feb 28, 2018 • Home
15helpful
2answers
I have this model and the outdoor temp sensor isnt working, and yes both modules have brand new batteries in them. what should i do to get the outdoor temp sensor to work.
My outside display stopped working, but the inside display still worked. I found that one of the two batteries in the inside unit was almost all the way dead. Once I replaced both batteries the outside display worked. I also checked the batteries in the outside unit. After all batteries were installed, I pushed the small button that is inside the battery compartment on the outdoor unit. It's now working perfect..
Measuring Tools & Sensors Logo
Top Taylor Measuring Tools & Sensors Experts
Are you a Taylor Measuring Tool and Sensor Expert? Answer questions, earn points and help others
