Just shut off and now no power going to it., unplugged and try powering it up with button on tv not remote and still nothing.
  • Televison & ... Master
  • 5,638 Answers
Restore Deleted Files on Samsung
The Android data recovery
could be best helper to recover deleted files on Samsung thoroughly. It is a professional data recovery tool good at restoring deleted data from Android device. A various types of Android data are supported, for instance, contacts, text messages, photos, videos, call logs, WhatsApp messages, apps data and more. It could be used to perform Android data recovery for any data loss causes.
More importantly, this program have other function, which are Android data backup & restore, recover data from broken Android. It is compatible with almost all models of Samsung and other Android models, including Galaxy S9/S8/S7/S6/S5, Note 9/8/5/4.
LEARN MORE
Posted on Oct 10, 2019
    Top Expert:
  • 9,098 Answers
TV Appears To Turn Off By Itself
support-us.samsung.com/.../pop_troubleshooting_fr...
Samsung ElectronicsMar 12, 2013 - There are four cases in which your TV either turns itself off or appears ... If you are using the TV as a monitor and the Stand-by light only blinks ...
Easiest TV repair - How to Fix Power [TV turns off, freezes ...
? 6:44
https://www.youtube.com/watch?v=OKklZpTGBGU
Apr 27, 2014 - Uploaded by Keith Fox
I just watch your video my tv won't stay on it keeps turning off I have a ... My Samsung 55" Smart tv suddenly turned off and won't come back on.
SAMSUNG TV REPAIR- TURNS OFF RANDOMLY - YouTube
? 9:24
https://www.youtube.com/watch?v=7Rj22VNhKXg
Jun 25, 2012 - Uploaded by Tampatec
EASY HOW TO FIX SAMSUNG TV- TURNS OFF RANDOMLY Clicking ... Samsung PN64 just started randomly shutting off and on usually with ...
Samsung Smart TV turning off - Forums - CNET
Posted on Jan 05, 2016
My RCA P60925BL won't turn on with remote or using the power button
Try by an other code for your device from the code list for your tV brand.
Jun 08, 2012 | RCA Televison & Video
Remote control work very slowly and sometime do not work
Please follow the troubleshooting steps:
  1. Remove the batteries from the remote control.
  2. Press each button on the remote control twice.
  3. Make sure none of the buttons on the remote control are jammed.
  4. Install fresh batteries into the remote control.
  5. Make sure nothing is blocking the Infrared (IR) sensor on the TV.
  6. On the remote control, press the TV FUNCTION button.
  7. Press the POWER button and other buttons to test the operation.
  8. Try using the remote control at varying distances from the TV.
  9. Power reset the TV by follow the steps:
  • Unplug the television power cord from the electrical outlet.
  • Let the television remain without power for 60 seconds.
  • Plug the power cord back into the electrical outlet.
Jan 09, 2011 | Philips 32PF9964 32 in. Television
Power wnet off and tv will not go back on
might sound daft but plug a lamp into the socket ware the tv was plugged in if that works check the fuse in the tv plug if all ok and still nothing unplug tv for a few hours and make sure power button is out (off) then plug back in then try power button and then try to start tv by the channel buttons on the tv instead of remote
Jun 05, 2010 | Insignia IS-LCDTV32 32 in. Television
Panasonic CT36SC13 remote or front power button will not turn off
Solution1:
a)Inside the tv there are microswitch CH+- Vol +- power, menu: when the ones are faulty," tv tends to behave at its own", change them, of course before to buy'em, unsolder th'em and try with the remote, tv has to work with out'em.
Apr 08, 2009 | Televison & Video
TV shut off Sony Trinitron KV-32S20
I believe this uit has a fuse on the AC input on the main PCB. Yu probably blew that fuse.
Jan 16, 2009 | Sony KV-32S26 32" TV
Only vizio light come on then nothing. have to unplug to turn off
there a problem on power side.. chage the ic and the resistor going to ic and check also the signal diode.
Dec 30, 2008 | Vizio L32 32 in. LCD HDTV
My RCA D52W20 will not stay on
Clicking sound is power relay engaging. If all systems are not functioning properly, unit will shut down to prevent further damage and/or fire hazard
Apr 12, 2008 | RCA D52W20 52" Rear Projection HDTV-Ready...
Power button Flashes
For the first one, please list the model number and count the blinks. Also, can you please post each problem separately. It will get too confusing trying to address 3 sets with different but similar problems.
Thanks,
Dan
Mar 18, 2008 | Televison & Video
Power cuts out on PT-53WX42
unplug tv check the fuse and the rating on it,.see if filament inside is burnt
Oct 23, 2007 | Panasonic PT-53WX42 53" Rear Projection...
Televison & Video Logo
601 people viewed this question
Top Televison & Video Experts
Marvin
Marvin
