[PDF]Compact Stereo System - FTP Directory Listing - Panasonic
ftp://ftp.panasonic.com/audio/om/schc25_mul_om.pdf
PanasonicOne that lets the sound come through loud and clear .... This function switches off thesystem (except in radio source) if you do not use the system for .... All phone features can only be controlled by the touch screen of the. iPhone. • The system ...
[PDF]Model: CQ-VD6505U - FTP Directory Listing - Panasonic
ftp://ftp.panasonic.com/caraudio/om/cq-vd6505u_en_om.pdf
Panasonicwater, is smoking, or smells), turn it off immediately and consult your dealer. ...components of your car audio system carefully before using the system.Missing: touchscreen
SOURCE: electrical sytem dies then returns when cooled down
Ford has a technical service bulletin out that may fit your concern.
ISSUE:
The charging system indicator may illuminate or vehicle may not start. This may be caused by a discharged battery due to a poor electrical connection at the generator terminal.
2.0L
2.5L
SOURCE: car will start fine but will shut off as soon as I place in gear.
Here are the most common causes of surges, stalls at stops, low erratic idle speed, rough idle and engine hesitation, it is in most cases the idle speed control air-bypass valve and or throttle valve and upper intake, these area's get full of gunk and combustion residue over the miles and cause idle issues (stalls, low idle) like yours, Get a can of intake cleaner from any local parts store, not carb spray, intake cleaner, it is made by a company called CRC, remove the air intake hose to the engine, hold the idle high so the engine won't stall, then spray the can of cleaner into the intake while keeping the engine running, use at least 1/2 the can, shut down the engine and disconnect the battery for 5 minutes, then restart and complete a number of mixed driving cycles, town, freeway, stop and go etc., after a few days the problem will go away as the system will relearn to the clean intake.
SOURCE: Starts and dies y 10 minutes
Try replacing your fuel pump and check for possible dirts in your fuel system.
Rate this please
