Question about Sharp AQUOS LC-40LE835U 40" 3D 1080p LED-LCD TV - 16:9 - HDTV
Can not connect to aps(Netflix) - Sharp AQUOS LC-40LE835U 40" 3D 1080p LED-LCD TV - 16:9 - HDTV
Posted by Don Berlew on
twowheelin
    Habit-Forming:
  • 166 Answers
You can check your internet setting under Menu->Initial Setup->Internet Setup and Communications setup.
Posted on Feb 06, 2016
Netflix ap just says start your free month now.How do I clear this request from the screen?
Hello Friend
If you're seeing steps to sign up for a new account when you try to sign in to Netflix, follow the steps below to return to the sign in page.
If you are watching on Netflix.com
1.Sign out of Netflix by visiting netflix. com/logout.
2.Select Sign In.
3.Enter your Netflix email and password.
For any help or support just visit us: Netflix Com Activate
Apr 09, 2017 | Netflix
The aps do not come up when you hit the button.
Did it ever work then if it did probably something in the download process failed . uninstall and try it again .
Sep 13, 2015 | Televison & Video
Works with my laptop, my smart phone and most of the smart TV aps. Cannot connect to NETFLIX from my TV. I can connect when I bypass the router.
Have you tried using an Xbox Wii or Ps with your tv, cuz some TVs with build in Wi-Fi just never work right. Also plug it straight in to your router check in settings for an update, good luck
Jul 06, 2015 | Computers & Internet
How do I get the youtube, Netflix and other features on my 55" magnavox to work. Cant connect.
Are you trying to connect to Wireless or wired? I had to use an option (for wireless) that is something like wps or aps maybe, anyway it's where you have to push the button on the router and select the option in the tv network menu and I got mine to connect. It wouldn't connect to wifi like phones and tablets do. Hope this helps.
Feb 10, 2015 | Computers & Internet
Can't log in Engenius EAP-3660 .after rest factory settings.why? can you help me pls
You don't seem to understand what an Access Point is.
an AP is used to extend your wireless range and will connect to your routericon1.png to provide network and internet access. An AP by itself cannot connect to the ISP since it does not use a WAN port
a router is an AP that will allow you to connect to your ISP for internet connection. A router can be configured to work as an AP but a AP cannot function as a router.
Read the manual. When you reset the AP the IP of the AP device became 192.168.1.1
That means you need to set the IP address of your computer to 192.168.1.x where x is anything from 253-2 and the subnet mask to 255.255.255.0
Feb 19, 2014 | EnGenius Computers & Internet
How to resolve wifi access mode not supported
an AP is used to extend you wireless range and will connect to your router to provide network and internet access. An AP by itself cannot connect to the ISP since it does not use a WAN port
Feb 19, 2014 | Linksys Business Series WAP4400N...
Aps removal
call samsung. i believe there is a weird button sequence that needs to be done.
Feb 09, 2014 | Samsung UN40D6500 40 in. TV
I have 5 scanners and 3 access points in my warehouse and the scanners only stay connected when I only have one access point turned on and the scanners set to connect to that access point (Mandatory), then...
Hi, that is happening because your 3 APs have the same fixed IP address. you have to change the ip address on 2 APs, right now it seems to be that your 3 APs have the same fixed IP address, for example in my warehouse, for AP #1 is 10.20.40.30, for AP #2 is 10.20.40.31 and for AP# is 10.20.40.32 hope it helps!!
Dec 06, 2010 | Symbol MC9090 Barcode Scanner
Connect belkin f5d7130 to homehub 1.5
You need to connect all pc's and homehub to a switch so they can talk to one another. Then use the AP as a wireless access point to connect all wireless laptops, and connect the AP to the switch with ethernet cable, and you have a network. Just make sure that only your HH or AP supplies IP addresses or they will clash.
Oct 19, 2009 | Belkin Wireless (F5D7130) 802.11g/b...
Sharp AQUOS LC-40LE835U 40" 3D 1080p LED-LCD TV - 16:9 - HDTV Logo
143 people viewed this question
Top Sharp Televison & Video Experts
Muntejaya Ginting
Muntejaya Ginting
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
