SOURCE: car will not start
replace the battery in the key fob and unlock the car with that, if u last locked the car with the key fob, you armed the alarm and can only be disabled by unlocking with the key fob, the car wont start because its an anti theft feature.
SOURCE: program factory remote keyless entry for 2003 Hyundai XG350
This bulletin supersedes TSB# 02-90-001.
DESCRIPTION:
The security system keyless adapter cable (SPX/Kent-Moore P/N 09900-21300) is a special service tool (SST) that is used for programming new keyless entry remote transmitters to the factory security systems. The keyless adapter is used in conjunction with the Hi-Scan Pro (with Hi-Scan SOL Pro Software Version 09-29-03
or newer) and Data Link Connector (DLC) Cable.
SERVICE INFORMATION:
The keyless adapter cable can be used on the following vehicles:
NOTE
SHOP MANUAL
PAGES
2004 MY Elantra
BE-73 - BE-74
2004 MY Santa Fe
BE-43 - BE-44
2004 MY Sonata
BE-40 - BE-41
2004 MY XG350
BE-46 - BE-47
KEYLESS ADAPTER CABLE INSTRUCTIONS:
and press ENTER
NOTE
"Release date 29. Sep. 2003" OR LATER
must appear on this screen. To update your SOL card with the latest software go to www.hmaservice.com and refer to TSB 00-00-001.
and press ENTER
and press ENTER
on the Hi-Scan Pro and verify that the remote(s) are functioning properly.
and disconnect the adapter cable from the multi-purpose connector.
SOURCE: fix a dead keyless entry system on an expedition
Did you try a new battery in keyless entry?
if not that may be your problem.
hoped this helped.
SOURCE: my keyless entry does not work so i unlocked the
First change the battery in the remote first. Then try the following even if the alarm is still sounding.
1. Get in the car and close the door.
2. Turn the key to the ACC position
3. Push the unlock button on the remote until the blinkers flash once.
4. Get out of the car and test the remote. It should be working fine. ( I actually was able to test it while in the car)
SOURCE: Remote won't unlock/lock doors. Car alarm goes off
Go to the dealer and get your remotes reprogramed
Press the UNLOCK button on the keyless entry transmitter.
Insert a valid key into the ignition and start the vehicle.
To disarm the CTD system in the armed mode:
To disarm the CTD system when activated, alarming mode.
