Hi try this set up to check if you're scart set up isn't the problem connect 3 rca lead to the output of the vcr into the input of video recorder then plug 3 more leads from output of video recorder into the TV set you're TV to AV INPUT AND set YOURE VIDEO RECORDER TO THE CORRECT INPUT MODE ...good luck
It could be that the dirt on the lens is too bad. You might have to take the top off and clean the Lens with Servisol Video 40 or other lens cleaning fluid. However the lens can also be damaged by a tiny piece of grit hitting it a high speed. Only observation by a powerfull magnifying glass will confirm this. Another problem could be damage to lens carriage unit, so it can't move to read the disc.
Actually, the TV is only a display device. It's just there to show you the picture from the PVR, and you're free to pick any model PVR with the features you want and a price you like. The only thing you need to be concerned about is connecting the PVR to the set.
Your Sony should have audio and video input jacks on the rear panel. (I'm assuming you have a Sony since your question is posted under that heading, but that's not always the case.) Almost every model has at least one set. These older models usually only offer composite video input with a single yellow RCA jack, and a pair of jacks (red and white) for stereo audio input. When you pick a PVR, just be sure it has a composite video output available. I haven't seen one yet that doesn't, but there a lot of models out there. If your model also happens to provide a component video input (with three RCA jacks, colored red, green and blue), that's even better. Component video gives better performance, and it's a standard output on PVRs and other video devices.
All you need to do is connect the PVR video output to the TV and select that input. You can connect the audio output to the TV, or use your home stereo receiver and speakers instead if you have a system. This might give you enhanced sound performance.
If your TV is a model not equipped with AV inputs (true for some very basic models, especially smaller screen sizes), you'll need an RF modulator. The TV can only pick up signals from its tuner, and that's where the modulator comes in. It takes the video and audio from the PVR and makes a channel 3 or 4 signal to the TV's antenna input. You might find a PVR with a modulator built in, but that's pretty rare now.
Hi Thanks for using FixYa. Two things that will cause
the “No Signal” message to come up are - no data available for closed
captioning and a weak signal input. Your TV is in the Closed Captioning Mode.
To turn it off simply bring up the on screen menu and scroll down to the part
that says closed captioning and turn this function off! With the closed
captioning block displayed and the program being viewed is not sending out
closed captioning signals the TV will display, No signal! If this doesn’t resolve your issue then the problem may be
with the processor failing and it is causing a random read of the EPROM to
display the not available message. I’ll suggest you to run the HDMI from the
PVR (personal video recorder) directly to the TV (mute the TV), and then run
the optical audio from the PVR directly into the receiver's optical in. The
closed captioning is something that is addressed in analog broadcasts, but not
necessarily digital broadcasts Try using Component cables if this doesn’t make a
difference. After using components cables the issue will be resolved. Please do
accept the solution if the issue is resolved or post a comment for further
assistance. Thanks Rylee
Thanks for using FixYa. Due
to two things that will cause the No Signal message to come up are – no data
available for closed captioning and a weak signal input. Your TV is in the
Closed Captioning Mode. To turn off simply bring up the on screen menu and
scroll down to the part that says closed captioning and turn this function off!
With the closed captioning block displayed and the program being viewed is not
sending out closed captioning signals the TV will display, No Signal!
issue then the problem may be with the processor failing and it is causing a
random read of the EPROM to display the No Signal message.
from the PVR (personal video recorder) directly to the TV (mute the TV), and
then run the optical audio from the PVR directly into the receiver's optical
in. The closed captioning is something that is addressed in analog broadcasts,
but not necessarily digital broadcasts.
this doesn’t make a difference. After using components cables your issue will
be resolved.
Please do accept the solution if
the issue is resolved or else revert for further assistance.
Have you tried to use a disc cleaner on it? If no go on that, you can also carefully clean the lens by opening up the unit and get the optical pickup (tiny lens) accessible. Then you can lightly and gently clean it with a qtip.
I own this model and do have the manual; however, standard AV and S-Video connections do not transfer progressive scan video images. If you hookup a progressive scan output to a non-progressive scan TV input, you will not get an image, so it is probably the way you have your machine connected to your TV that is the problem. If you are trying to watch regular TV through your machine, you will probably need to use a standard Coaxial Cable. I hope this helps.
