Question about Exercise & Fitness
We need to disassemble the treadmill is this okay
Posted by Susan Ketelsen... on
Sportsmith LLC
  • Exercise & F... Master
  • 918 Answers
Replacement Parts for Fitness Exercise Equipment at SPORTSMITH
I would suggest locating an assembly manual to get familiar with the process before disassembling the machine. If you provide me with a model and serial number, I may be able to help you further by locating a manual for you.
Posted on Jan 04, 2016
Disassembling my 1500 nortic track treadmill
The following link is to a manual for your model. This should provide some insight before disassembling the unit. The most important part is to label the connection wires so that you are sure where they go when you put it back together. Also be considerate of any pinch points so that you do not accidentally pinch or crimp any wires when putting it back together.
249920 NORDICTRACK 1500 TREADMILL SPORTSMITH net
Jan 04, 2016 | Nordic Track NordicTrack Commercial 1500...
I need reading AR but log in my number and password but I can't open for that thank you
Looks like this item is a rack that fits on a treadmill, so you can walk and read at the same time. Is that what you want to buy? Or are you trying to log into an online AR reading program? Accelerated Reader at your school? If so, you need to ask your teacher what the number and password are. It is whatever they put in for your, like your student number or something.
Nov 04, 2014 | RTO 2-pack Compact Reading Rack/ Treadmill...
How do I disassemble my tx390 treadmill to transport it?
This can be interesting as there are a lot of bolts to disassemble. I tip mine up and lay it down in a pick up truck or a van you can take the seats out. They are very heavy so you need help.
Oct 03, 2014 | Sportcraft Exercise & Fitness
Belt don't move
you may have to adjust tension notch at a time and see if it makes any difference.
Mar 24, 2014 | Smoothfitness Smooth 6.17 Folding...
What is the easiest means of partially disassembling and moving an Epic 35 Treadmill?
1) is more easy to fold 2) However if the place is impossible to move you must disassemble the treadmills read your owner manual or download from www.fitness.manualsonline.com see the video attached.
God bless you
Oct 08, 2013 | Epic View 550 Treadmill
When walking on treadmill its sticking not smooth like it used to be and noisy
Hi, You need to do some lubrication on moving parts such as bearings, motor (use a light oil).
Some disassemble is required. Good luck
Jul 13, 2011 | Exercise & Fitness
Need to disassemble NordicTrack X7i trainer to move it. Don't have the manual
To get the manual go to iconservice.com and select the manuals link. You will be asked the model name or number. You can download a PDF file of the manual for free. Use the assembly instructions only backwards and you will be able to disassemble the machine.
Aug 10, 2010 | Nordic Track Nordictrack Apex 6500 Reflex...
Proform 740CS runs okay but the incline does not
ProForm Treadmills have a reset procedure for the incline function. With the key inserted in the console, activate the incline; while the incline is changing, remove the key. Wait 30 seconds, then replace the key. The incline should to maximum, then to minimum, resetting its limits. It worked for mine just 10 minutes ago; the procedure is in the manual if you have it. Good luck!
Mar 09, 2010 | Proform 7.0 Crosstrainer Treadmill
Need to dismatle to move and can't
There are a lot of different treadmills and stairways that require specific solutions, but there are some general solutions.
You say you can't disassemble it, so try forearm forklifts, they can make a 2 person lift very manageable. Also if you have a large piece of cardboard (and once again, 2 strong people) the cardboard can be used to both provide a surface that will slide up the stairs and distribute the weight over a larger area, so you can actually put it on it's side without causing damage.
I've used this technique and it works with a little caution and muscle.
Oct 17, 2009 | Exercise & Fitness
Pro-form 320x treadmill slows down then motor stops.
Sounds like it is overheating, you have to disassemble the unit and find why it might be overheating
Aug 29, 2009 | Nautilus Tr300 Treadmill
Exercise & Fitness Logo
179 people viewed this question
Top Exercise & Fitness Experts
Tom Chichester
ray gallant
Marvin
Marvin
Are you an Exercise and Fitnes Expert? Answer questions, earn points and help others
