Question about Frigidaire FGET2765KF
Self cleaning mode towards the end of its cycle went into a failure code cleared it by flipping breaker. Now when I run bake/convection it runs broil at 600. Lower oven now run under temp.
Claude Kayser
    Top Expert:
  • Frigidaire Master
  • 9,098 Answers
Amazon.com: Frigidaire Gallery 27 In. Stainless Steel ...
www.amazon.com/Frigidaire-Gallery.../B002HMRIBI
Amazon.com, Inc.
Rating: 4 - ‎4 reviews
When your appliance is delivered it will be brought into your room of choice and all ...The Frigidaire FGET2765KF Gallery Series 27 In. Double Electric Wall Oven, ... Using the "Quick" Pre-heat function on this oven, the timer goes off ... Great, until you check the temperature and find that it's only reached 225 degrees.
Frigidaire FGET2745KF Gallery 27 Double Ele
Frigidaire Model FPDS3085KA getting error code F90 ...www.shopyourway.com > Manage My Life > QuestionsMy wife did start the self cleaning and cancelled it and we have not been able to ...Frigidaire Model FPDS3085KA getting error code F90 ... I have tried holding the lock button down for 3 seconds and that puts it into a mode where it looks like it ...Missing: fget2765kfFrigidaire Range Error Codes for Self-Cleaning Rangeswww.searspartsdirect.com/.../error-codes/frigidaire-self-cleaning-range-e...Find error codes for your Frigidaire self-cleaning range at Sears PartsDirect. ...should only occur when the oven is active or when you attempt to enter a mode.Missing: fget2765kfFrigidaire Self-Cleaning Wall Oven Error Codes ' Sears ...www.searspartsdirect.com/.../error-codes/frigidaire-self-cleaning-wall-ov...
Posted on Jan 03, 2016
Self cleaning mode had failure. Cleared by flipping breaker. Now runs bake/ convection mode with broiler at 600 + degrees and lower oven operates under temperature. I think temperature sensor error
Hello Pamela, thanks for your post!
From my understanding your Frigidaire range had an issue when it was in self-cleaning mode. It sounds like your thermostat or control panel may need to be replaced. I would suggest seeking help from a professional technician this will help you to avoid any unnecessary part purchases or improper disassembly of your range. Hopefully this information is helpful to you. -Matt
Jan 03, 2016 | Frigidaire FGES3045KF Gallery 30" Slide-In...
Oven won't heat.
Good Afternoon Gwen - Try reprogramming the range by unplugging it or flipping the household circuit breaker off. Wait approximately ten minutes and turn the unit back on. If issue persists, then the unit could possibly be experiencing an issue with a wiring failure, EOC (electronic oven control), sensor probe and/or faulty bake or broil element. I would strongly recommend consulting a professional to narrow down the precise issue before investing in parts that may or may not be the root cause.
May 15, 2013 | Frigidaire Gallery 30" Self-Cleaning...
Bottom element doesnt work in oven, but top does.
NOPE!
  1. Broil element does not have welded-on legs and will touch the bottom of oven, overheating itself and will end up the same way your bake element did; besides, the bottom of the oven will corrode pretty quick
  2. Many ovens use both elements during bake cycle
  3. self clean cycle uses broil element
  4. The bake and broil elements typically have different mounting brackets and screw holes ate in different places
  5. you'd have to cover the hole, left after removing the broil element, and insulate the wires, which went to broil element
  6. the ends, protruding behind the mounting bracket may have different length and different connectors. you may end up shorting the wiring to the casing, which may in turn destroy the control board if there is one
  7. Bake elements usually cost only $40-$60. No jury rigging required.
Hope this helps ;)
Mar 29, 2010 | Ovens
Amana AGR5735QDS. Bake/Broil don't work, Clean/burners do work
Hello- Most problems with todays ranges start after 'self clean', or as most techs call it- 'self destruct'. If control functions normally, the temp can be run up manually by holding button down until it reaches 500deg., then holding it down until it stops and reads 0 or +/- 5,10, etc. This is a temp adj. mode. If it won't adj. or work at all, control is bad. If it works, then twin ignitor failures are not unheard of. Resistance across either ignitor should be above 4 ohms., if not, they have failed. Avoid 'self clean'. Tears electronics up and wastes energy. Use drip pans and try to forsee boil overs. Grandma figured it out a long time ago. Hope this helps. Thanks- ED
Mar 01, 2010 | Amana AGR5735QDS Gas Kitchen Range
The oven doesn't turn on in the bake cycle
oven doesn't come in broil but the broil should . the bake should in bake . but if it does work in self clean then your oven is ok and its the clock ( erc) that has failed . some times there is a code in the display stating the problem. but ist loks like a clock failure . **** ..
Dec 23, 2009 | Amana AGR5735QDS Gas Kitchen Range
Jennaire broiler doesnt work on slidein range after using self clean oven. Its only 14 mo. old
if just your broil element does not work and the bake element does work after using a self clean cycle then your broil element must have went out , self clean is a torture proccess for any self clean oven and it runs both elements at 500 deg. F, it may be still under warranty , if not then replace the broil element for the fix.
Phil
Jun 10, 2009 | Jenn-Air JES9860 Electric Kitchen Range
Oven will not heat up on bake broil or convection cook.
I justn encountered the same problem (Model KERS507Y). Haven't checked yet...but am suspecting the Thermal fuse. Have you solved the problem?
Jan 18, 2009 | KitchenAid Architect Series KEMC308KSS...
Dacor oven ECPS127S will not heat after self clean
the problem was fixed by opening the panel between the oven cavity and the touch panel just behinf the door. you can look through the grill but to trip the reset you must unscrew the panel. you will find the reset back behind the wires Looks a red button nestled on top not very open but it should be there> i do have to say i found a step by step description on this site. but right now i can't tell you who exactly he was.
Feb 16, 2008 | Dacor ECS127 Epicure Stainless Steel...
GE Profile XL44 Spectra gas oven
try to hold down the light switch on the door set it up for another cleaning hit start when oven clean door lock showes hit cancel if that doesnt work try unplugging it for three min fyi the doors can take up to an hour to un lock after cleaning its so it dont burn your face off from the intense heat after cleaning some take 2
Feb 14, 2008 | GE Profile JGS968 Gas Kitchen Range
Frigidaire FGET2765KF Logo
201 people viewed this question
Top Frigidaire Heating & Cooling Experts
Steve Oakes
Steve Oakes
Mike
Are you a Frigidaire Heating and Cooling Expert? Answer questions, earn points and help others
