Question about Panasonic Audio Players & Recorders
5 CD changer, model sa-ak600. What does code f61 indicate?
Nothing works no buttons works and fan is not working when you touch a button code f61 comes on
Posted by don weatherbee on
Grubhead
  • Panasonic Master
  • 5,700 Answers
F61 means that the power amp has something wrong with it.
It could mean the IC501 has failed or that there is something wrong to the power supply to it.
The good news is the service manual is free online. You can get it by simply putting the model number into google and searching for the PDF of it.
Posted on Jan 03, 2016
Error f61 on my panasonic sa-ak330
The f61 code is believed to be an amplifier circuit fault, but in reality it more often than not turns out to be a problem with a jammed up motor elsewhere(fan, cd changer motor, cassette motor). For me it was a jammed up cd changer. I simply disconnected the control for the changer and operation resumed as normal.
Mar 30, 2013 | Audio Players & Recorders
My panasonic sa-ak600 cd player doesn't switch on. I checked the fuse inside the unit and found which was good. hopefully, someone can figure it out. thanks
I had the same problem. My unit would turn on, display F61, and turn off. I looked at the manual. It said if you see 'F61', check and correct the Speaker Cords connection. If this does not fix the problem, there is a Power Supply problem. Consult the dealer. Hope this helps.
Oct 04, 2010 | Panasonic SC-AK600 CD Shelf System
Unable to Open F61 error flash on screen
TIMING ADJ...AC DISCONNECT !!
OPEN TOP LID
CHANGE MAIN BELT BY MOVING THE TRAYS.
PLUG IN AND CHECK
IF NOT NEED ADJUST TIMING FOR THE WEELS.
ONLY EXPERTS
FREDDY.R
ISRAEL
Nov 11, 2009 | Panasonic SC-VK31 220 Volt 5-VCD/CD...
My SA-VK70D got F61 and imediatelly turn off..:(
i have vk70d and i have same problem .....your cooling fan not working ...chand it ...its work ....
Sep 03, 2009 | Panasonic SCAK410 5-Disc CD Changer
CD Changer doesn't work after changing battery on Jeep Liberty 20
The CD changer probably failed to establish it's link to the head unit when you put the new battery in.
Since you've already tried the clear button, I'd suggest unplugging the IP-BUS cable (black cable) from the back of the changer, wait a minute (literally, 60 seconds) and plug it back in.
Jul 20, 2009 | Jeep 2003 Liberty RBQ AM/FM Radio w/...
I have a f61 fault code on my sa-ak600 panasonic audio system
Replace IC500 on power circuit board.
The board at the bottom with heat sink.
STK470-090 voltage regulator Sanyo original.
Dec 22, 2008 | Panasonic SC-AK300 CD Shelf System
Panasonic SA-AK600
Try to power on the unit without the speakers connected. If it works normally without the error showing, then a speaker wire maybe shorted or a speaker defective. If the error F61 is still there, then most likely the Regulator IC is defective in the unit.
May 30, 2008 | Panasonic SC-AK600 CD Shelf System
Panasonic SA VK550 - F61 eror
Hi, i had the same problem with a panasonic player, when you see the code F61 in the screen it is because the audio output IC is defective,change that and the set will work perfectly. hope it work.
Feb 05, 2008 | Panasonic SC-AK33 CD Shelf System
Nide code fore a panasonic cd stereo sistem
Most likely the regulator IC is defective. Part # C5BA00000105.
Jan 15, 2008 | Panasonic SC-AK600 CD Shelf System
F61
i had the same problem with the error code f61.There are 2 fans,1 external and 1 internal and were both working but were very clogged up with dust thus working harder.Try cleaning them both it worked for me on the SA-HT 990 model
Jan 10, 2008 | Panasonic sa-ht800V Home Theater Audio...
363 people viewed this question
Top Panasonic Audio Players & Recorders Experts
Muntejaya Ginting
Muntejaya Ginting
 Grubhead
Grubhead
Are you a Panasonic Audio Player and Recorder Expert? Answer questions, earn points and help others
